same problem over and over...
Old Apr 17, 2005 | 07:29 PM
1st timer's Avatar
UB6IB9
first time i brought my car in for stalling and rough idle they found a bad coil (so they said),a week later the problem came back,so they changed the pcm and fuel regulator(so they said),now 3 weeks later,i have the exact same problem,engine light went on along with the TCS and i had a hard time starting it,WHAT THE FUCK COULD IT BE(i think it's the damn dealer,they don't know what they're doing)
Anyone??????
Old Apr 18, 2005 | 10:39 AM
chilifrost's Avatar
What year and How many miles?
Old Apr 18, 2005 | 06:19 PM
1st timer's Avatar
UB6IB9
2000,47500miles
Old Apr 19, 2005 | 09:33 AM
PeteTLS's Avatar
I have no idea how to check it, but a friend of mine with a TL ('01 I think) said he had a bad Idle Air Control Valve......
Old Apr 19, 2005 | 07:29 PM
1st timer's Avatar
UB6IB9
the dealer still can't find the problem,the light is on but they don't know what's causing it,i hope they don't charge just for checking,it's day #2,the problem is a misfire in a cylinder,anyone else had this problem?
Old Apr 19, 2005 | 08:11 PM
swift22's Avatar
luvs redheads!
Question check
how bout spark plug and injector to start with basics????
Old Apr 20, 2005 | 12:38 PM
1st timer's Avatar
UB6IB9
Angry
day 3 and no progress...
Old Apr 20, 2005 | 06:03 PM
1st timer's Avatar
UB6IB9
Unhappy
got my car back this afternoon,dealer said they could not figure out what the problem is cause it's no longer there.
Old Apr 20, 2005 | 08:55 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Give me an "E".. give me a "R".. give me a "G" valve.
Old Apr 21, 2005 | 09:00 AM
chrismeoli's Avatar
clean out the intake and egr with some good carb cleaner! did it last weekend and i cant even tell my car is on anymore, its like brand new, we are in love again! btw,,, reset your computer when doing it!
Old Apr 21, 2005 | 11:45 AM
chilifrost's Avatar
Why do need to reset the computer?
Old Apr 21, 2005 | 11:52 AM
chrismeoli's Avatar
my friend in acura service said they reset the computer whenever they do anything like new plugs, tranny maintenance, o2 sensors and so on,,, it supposedly is supposed to make the computer realize to check everything again wneh it resets and it picks up on the new plugs, sensore, egr valve or what ever you did, the computer is resposible for adjusting the air/fuel ratios and all that good stuff,,, it may run richer than normal if you have fouled plugs or a bad o2 sensor, after you fix those if you reset it it is supposed to notice the changes that way and adjust things for you..
Old Apr 22, 2005 | 06:01 PM
@cUr@-TL's Avatar
'99 Acura 3.2TL
From Acura's 1999 3.2TL Service Manual:
If you get a misfire code, and the "check engine" light comes on at low rpm/idle, the problem is most likely: low compression, bad fuel.
If you get a misfire code, and the "check engine" light comes on at high rpm/load, the problem is most likely: valves, check clearance (that's what happens to me sometimes!)
If you get a misfire code, and the "check engine" light comes on at mid/high rpm/load, problem is most likely: VTEC, check system.
that'S what i have for now.
Old Apr 22, 2005 | 06:50 PM
1st timer's Avatar
UB6IB9
do you know what the compression has to be at?
Old Apr 22, 2005 | 06:51 PM
1st timer's Avatar
UB6IB9
so disconecting the bettery is good enough i guess?
Old Apr 22, 2005 | 08:37 PM
lbbrando's Avatar
Acura Dealer Technician
The pcm is and will constantly check all values whether reset or not and compensate for them. No resetting is needed when changing anything!
I have never done this and no tech in our Acura dealership has done this.
The only thing that you may have to do is the idle learn procedure.
I've changed injectors, plugs, o2 sensors, cats., transmission solenoids, even swapped engines that a customer blew up and have not reset the pcm, no problems at all in future(comebacks).
Old Apr 23, 2005 | 07:54 AM
1st timer's Avatar
UB6IB9
what should the compression be for a 00 TL-P?
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
