reverse sensing wire
Old Dec 18, 2011 | 08:38 PM
raydog318's Avatar
i need some help finding the reverse sensing wire for a 99 acura tl. trying to hook up a rear view camera. thanks
Old Dec 18, 2011 | 09:44 PM
02type-s's Avatar
-Arsenic-
Get a light tester (cheap). It will take 5 mins
Old Dec 18, 2011 | 10:42 PM
crownovercoke's Avatar
Your transmission range switch is on the transmission. The white wire is the reverse. It goes to a relay then to reverse lights. Not sure but I think taping anywhere between the relay and bulb should be enough to turn on camera.
Old Dec 19, 2011 | 10:45 AM
01tl4tl's Avatar
thats correct
must be AFTER the relay--thats where power actually comes out from after fuse protection
grab the white wire anywhere from there to the back up bulbs- thats an easy place to access the wires,,the bulb~
12 volt test probe or multimeter for numerous elect tests is a smart buy for every toolbox
5 bucks at parts store, harbor freight gives $4 multi meter away all the time, ck coupons
congrats on investing in safety with a camera!
Old Dec 19, 2011 | 03:05 PM
raydog318's Avatar
thanks!!!!!!!!!!!
Old Dec 19, 2011 | 04:16 PM
sammy95's Avatar
Get a meter. It's better!
Can't tell 12volts with a test light.
Old Dec 20, 2011 | 04:46 PM
TLer trash's Avatar
The wire color should be green/black. You probably have a trailer connector behind the carpet in the left rear quarter. The white wire is from fuse to switch, don't mess with it.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
