Require Maintenance P0170
Old Oct 5, 2019 | 01:24 AM
MaxBeast4Z's Avatar
Question Require Maintenance P0170
I wrote this on Google and it didn't help it's telling me idler control valve air flow sensor an O2 sensor the fuel delivery system engine timing I don't know.
So i got a new light that flashes in the dash they require for maintenance light it flashes for about 8 Seconds when starting the engine when the engine starts it's like if the idle control valve doesn't work but the code is not that I want to know exactly what it is be four this causes me a ton of problems.
Old Oct 9, 2019 | 10:33 AM
Saudade's Avatar
USAF Veteran
Veteran: Air Force
To reset the Maintenance light:
Turn the key to off position.
Press and hold the SELECT and RESET buttons on the instrument panel and turn the ignition to position (II).
Continue to hold buttons until the indicator disappears.
Turn ignition off and then start the engine to verify the indicator has been reset.
Reset your codes, then drive around for a few days and see if your Check Engine light comes on, then pull the codes again.
General info for the P0170 code is:
https://www.obd-codes.com/p0170
Old Oct 9, 2019 | 07:09 PM
MaxBeast4Z's Avatar
It works the light does no longer flicker I don't know what that light is for exactly we already have the check engine light why I need that light.
Old Oct 9, 2019 | 09:54 PM
Saudade's Avatar
USAF Veteran
Veteran: Air Force
It’s a maintenance reminder like oil change, tire rotation, etc. it does not indicate any problem.
The check engine light is the one to be concerned with.
Eric Yacyshyn
Jan 29, 2016 10:50 PM
jeremystartzy
1G CL Problems & Fixes
Dec 1, 2012 01:35 PM
04TL4P3
May 25, 2010 03:49 PM
namesake
May 23, 2004 10:19 AM
97 3.0
Sep 12, 2001 10:26 PM
