Replacing Fliter!!
Old Nov 2, 2002 | 03:04 PM
yitbos's Avatar
Replacing Fliter!!
I bought a K&N filter, went to remove the old filter from my tl, and the freaking screws won't move at all. I grapped my electric screw driver, nothing. As anyone ran into this probelm before? And what tools did you use?
Tony
Old Nov 2, 2002 | 04:16 PM
ABDomega's Avatar
2011 SH-AWD 6MT
I just dropped my K&N two weeks ago. I didn't have much problem unscrewing the screws with a philips screwdriver. Are you saying you can't get any turn on the screws or they won't come out? Because they don't come out completely, they stay on the filter lid.
Old Nov 2, 2002 | 04:26 PM
yitbos's Avatar
I can't get any movement on the screw. I didn't know that they don't come compeletly out.......but yes, there is no movement. I am at work now, and wanted to do it while I was here. I'll make to wait then until I can use another tool at home
Old Nov 2, 2002 | 07:08 PM
puggy's Avatar
how old is your car
Old Nov 2, 2002 | 07:40 PM
Strannik's Avatar
Use 8 mm socket w/rachet on it - I coudn't get my to bulge with screwdriver either.
Old Nov 2, 2002 | 08:41 PM
yitbos's Avatar
thanks strannik, i only have a 99 tl, but i haven't replaced the filter since I bought the car w/ 32,000 on it, and now it has over 50k, so i figured i should.
Old Nov 2, 2002 | 08:53 PM
ABDomega's Avatar
2011 SH-AWD 6MT
I'ts pretty Ironic. I bought my '99 TL with 35k and put in my new filter just a few weeks ago at 50k. I enjoy the K&N, kind of makes me use autostick more often.
Old Nov 2, 2002 | 09:06 PM
yitbos's Avatar
I have a question, I think I am starting to notice the steering wheel shake a little, just a little, when I brake. did you replace your rotors or brake pads already?
Old Nov 2, 2002 | 09:59 PM
jean's Avatar
Re: Replacing Fliter!!
Tony
I instaled my K&N last year on my '02 TL-P
barely had 4k on it and those screws were on tight...(factory)
really had to lean on the screw driver.. got a little snap and they were loose, and they dont come out.. they stay attached to the lid.
J
Old Nov 3, 2002 | 09:41 AM
Strannik's Avatar
You are welcome
I got my pads/rotors replaced under warranty @ 25k miles - had the same problem. I have 2000 TL, around 30k now.
Old Nov 3, 2002 | 10:34 AM
ABDomega's Avatar
2011 SH-AWD 6MT
I usually take it easy on my brakes which may give reason for them not shaking the steering wheel. I haven't had that problem but when i do I will replace the pads and rotors. Maybe at 60k?
Old Nov 3, 2002 | 12:00 PM
yitbos's Avatar
I should probably take it easy and not drive like a manic!!! ABDomega, are you from Buffalo? I am orginally from Albany, NY, and love the Bills.
Old Nov 3, 2002 | 12:08 PM
ABDomega's Avatar
2011 SH-AWD 6MT
Yeah I'm originally from Buffalo but I am at school in Cincinnati. I'm still a diehard Bills fan though. I really hope they scold the Pats today. That would be so sweet, this is a huge game. Bills are best team on paper in offensively for the AFC.
Go Billies!
Old Nov 3, 2002 | 12:58 PM
SilverUA5's Avatar
Did you wash your car after a long drive and the rotors are still hot? When the rotors are hot and you spray cold water on it, it will warp and give you that shaking feeling. Best thing to do is to turn your rotors if it's not too old.
Old Nov 3, 2002 | 01:37 PM
yitbos's Avatar
I never washed it after a long drive, I wash the car at my complex. I am going to get everything checked before thanksgiving. thanks for all the inpu
Old Nov 3, 2002 | 07:43 PM
lhommec13's Avatar
"Bills are best team on paper in offensively for the AFC."
But the better team won today (by 31 points).
Old Nov 3, 2002 | 10:20 PM
IXLR8TL3.2's Avatar
yes, that should do the trick, and if for some odd reason you strip the bolt end of it.. i suggest using Craftsman's Screw Out, it goes on the end of a drill, those little bits work wonders
Old Nov 4, 2002 | 05:15 PM
BLEXV6's Avatar
Sounds like the screws are seized. Use some WD-30.
Old Nov 4, 2002 | 10:27 PM
samkws's Avatar
Comptech Freak
does the K&N filter makes the car revs louder?
Old Nov 4, 2002 | 10:57 PM
TLS RULZ's Avatar
I want to know too, since I'll need a new filter in a month or two.. And anybody know how much in CAD $?
Old Nov 4, 2002 | 11:02 PM
ABDomega's Avatar
2011 SH-AWD 6MT
I guess it's debatable to whether it does. Because if it does make it louder it isn't a thoroughly noticable difference and it only comes in at higher revs. I feel that it does but it shouldn't affect whether you go for it or not because it doesn't make the car any louder at cruising speeds.
Old Nov 5, 2002 | 01:08 AM
samkws's Avatar
Comptech Freak
stephen says 40 bucks at pacific mall~
what a gd deal
Old Nov 6, 2002 | 08:19 PM
yitbos's Avatar
just finished installing the filter, pretty easy once I got those freakin screws loose. so what do you guys think, remove the RESONATOR BOX!!! no, yes
csmeance
Jan 7, 2026 06:25 PM
cycdaniel
Dec 17, 2019 10:58 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
niray9
Dec 8, 2015 07:34 PM
Billu99tl
Sep 13, 2015 11:30 AM
