Removing Tranny Help
Old May 17, 2012 | 02:15 PM
Vman159's Avatar
I got an 07 Accord Tranny but i am a little mechanicaly inclined. I understand i need to unscrew the axeles and stuff. but is there a thread on the process because i couldnt find one. Thank you
Old May 17, 2012 | 02:54 PM
victus1's Avatar
Oh man, I'd love to see a DIY on this.
Will you be doing this job on a lift, or can it be done which jacking up the car on the floor?
Old May 17, 2012 | 03:19 PM
Vman159's Avatar
It can be done on a jack on the floor but with blocks on the jack to make it stand high
I wish i could do a diy but my camera broke lol and I spent most of my paycheck on the new tranny.
Old May 17, 2012 | 05:27 PM
Karanx7's Avatar
Unregistered Member
Just get a service manual and read along.
Little long for a DIY
Old May 17, 2012 | 05:37 PM
victus1's Avatar
Here is a copy of the service manual.
http://dl.dropbox.com/u/71229813/!!!...E%20MANUAL.pdf
Right-click the link and select "save link as".
Old May 17, 2012 | 05:58 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
They switched the tranny design halfway through the 07 year. You have a 50/50 chance that it wil bolt or not before you get to far with it
Old May 17, 2012 | 06:42 PM
Vman159's Avatar
I read that was only the tl not the accord. How can i tell if itll bolt up. Theres no way to really see how it fits without taking it out... not that i know of atleast
Old May 17, 2012 | 06:44 PM
fsttyms1's Avatar
No need for a lift, or blocks under the jack stands. I've changed 4 in my garage.
Oh and there isn't a diy for this. There are too. Many things and steps to make it a DIY.
Old May 17, 2012 | 08:13 PM
MilwaukeeDave's Avatar
You make the most unenviable of tasks seem so simple and mundane, fstty.
Old May 17, 2012 | 10:35 PM
Oops I don't know how I completely misread that, carry on
Old May 19, 2012 | 08:46 PM
fsttyms1's Avatar
its really not that hard. Just because its a Transmission doesnt mean its hard to do. Honestly other than its weight, its really no more difficult than changing the shocks and springs. If found getting the swaybar endlinks off to be more of a chore.
Old May 20, 2012 | 01:15 AM
Vman159's Avatar
I read somewhere that someone had to swap over the range switch. What is a range switch? pictures? other than that i dont need to swap anything over sensor wise?(07 accord tranny)
Old May 20, 2012 | 07:31 AM
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/2nd-gen-tl-auto-transmission-alternatives-753294/
There's alot of information in this thread here. Should have everything you need to switch in there
Old May 21, 2012 | 10:13 AM
Vman159's Avatar
Thanks for the thread but I didn't find a pictur of the range switch
Old May 24, 2012 | 01:58 PM
Vman159's Avatar
Ok i swapped in the 07 Accord tranny succesfully
seems to me like its working fine. My questions is: how long do i have to drive it like a grandma with new fluid till i can actually go WOT using sports shift?
Old May 24, 2012 | 05:50 PM
Karanx7's Avatar
Unregistered Member
1000 miles to be safe. Realistically, 100 miles.
It's not a new transmission, so it's already broken into.
Old May 25, 2012 | 03:01 PM
Vman159's Avatar
The swap went smooth.. other than my alignment is f'ed up
Old May 25, 2012 | 03:14 PM
acutee's Avatar
Any tips or tricks of what you went through to share with us all?
Old May 26, 2012 | 09:24 PM
Vman159's Avatar
It was really straight forward. It is really convient that our subframe splits in half so we dont have to take the complete thing off. Swap out the range switch sensor other than that everything else fit perfectly. Make sure you have all your tools. Mine were scattered around the garage before i started the swap so it took sometime to find the right tools. No special tools were needed besides ratchet tools, and a jack. Make sure to get a jack that can pick up your front end fairly high because i had to use blocks of wood on top of my jacks. feel free to pm me if you have any questions and ill do my best to answer them.
Old May 26, 2012 | 10:58 PM
victus1's Avatar
Can you please explain how you dealt with the weight of the tranny after jacking up the front end. How did you lower the tranny after unbolting it? Did you use another jack? And please tell how you lifted the new tranny in place. Thanks.
Old May 27, 2012 | 03:15 AM
Vman159's Avatar
Basically after unbolting the tranny and removing the subframe i put a woodblock under the engine so i wont ruin my motor mounts. After unbolting all the bolts i took down the tranny with a jack with a block on top off it and with blocks on both sides so they will catch it if something goes wrong. Same thing with the new one. My friend and I lifted it unto the block and had blocks on both sides for safety. One person was operating the jack lift while the other was directing on what to do.
I did my best on explaining it. I am not a mechanic but this was really straight forward. The most hardest part for me was remembering where every bolt went back because i didnt label them
Pham Alvan
May 18, 2021 06:48 AM
Charles Bennett
Jan 28, 2018 08:53 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
Pham Alvan
Mar 16, 2016 09:17 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
