Removing Pinstrip
Old Jun 13, 2007 | 01:31 PM
radar989's Avatar
3rd Gear
Removing Pinstrip
I have a 03 TL-S and what to remove the pinstripe. I would assume that it was put on by the factory. There is clear paint at the paint at the beginning and the end of the strip. Has anyone removed their stripe before? I have a Porter Cable polisher/buffer to take car of any discoloration. Any thoughts??
Old Jun 13, 2007 | 09:00 PM
sistom's Avatar
pwnage
All you have to do is peel it up... It is pretty easy. It does leave behind a sticky trail of dirty along the edges of where the stripe was but you can get that off with soap/water/buffer. Good luck!
Old Jun 13, 2007 | 10:53 PM
02type-s's Avatar
-Arsenic-
It might not be just that easy. Mine for example is painted on I want it off...
Old Jun 13, 2007 | 10:59 PM
6MTUA5's Avatar
No He Can't
Yea I always thought mine was a decal, but I looked at it closer today and it looks painted on.
Old Jun 13, 2007 | 11:17 PM
tegkid's Avatar
spaz
well if you cant scratch up the side then its painted on
i know on my teg it was a decal and i just scratched and peeled the whole thing off
then i went back over it with a bottle of goo gone and got rid of all the stickyness
then did a whole detail just cause i felt like it
Old Jun 14, 2007 | 01:01 AM
orgnlprankster7's Avatar
08 Civic SI
since when did the tl have a pinstipe???
Old Jun 14, 2007 | 01:29 AM
desired_speeds's Avatar
2 words for you
Meguiars scratch-X
Old Jun 14, 2007 | 01:31 AM
6MTUA5's Avatar
No He Can't
since i bought it a few years ago
Old Jun 14, 2007 | 08:06 AM
radar989's Avatar
3rd Gear
I know that it is a decal; it may have been installed by the dealer. I will take a couple of before and after pictures. I am going to take it off!
Old Jun 14, 2007 | 08:21 AM
Evader's Avatar
Let's Go Pens
Mosts dealers have them professionally installed. Call your local deal and ask them who does their pinstriping work... Call the place that does the pinstripes and ask them for tips on how to remove it. A friend of mine did this a few years back and it worked wonders on his accord! It may look like paint but it's probably just a decal that was applied with a sealant. I would suggest a little goo gone to help losen the adhesive as well.
Old Jun 14, 2007 | 10:40 AM
precisionpar's Avatar
Precision1
If it's a decal pinstripe then 3M makes a product called "Stripe off Wheel" which is basically just a big eraser that you attach to a cordless drill and it removes the pinstripe extremely easily. You have to be careful not to let it "idle" in one position because it will burn the paint. After you're done you still have to use an adhesive remover. Bad news is it is a little pricey ($37).
Old Jun 14, 2007 | 02:21 PM
djmato's Avatar
Was it painted under the clearcoat? You can try to use ur nail to scratch it to check it is is under the clearcoat. It it is, no way to remove it unless you repaint, if not, there are plenty way to clean it. I had the exact same exp as you few months ago.
Old Jun 14, 2007 | 11:22 PM
02type-s's Avatar
-Arsenic-
Originally Posted by desired_speeds
2 words for you
Meguiars scratch-X
Are you serious? I have some of that stuff but I would have never thought to try it. Is that what you did?
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
