Rear Bumper Removal
Meridian
Rear Bumper Removal
Hey, does anyone have a DIY or instructions to remove the rear bumper? I've removed the front bumper a dozen of times but I just want a head up on how to remove the rear. Thanks.
If its anything like the 2G CL, then its really easy. I have removed it many times before without any help or DIY guides. I think its easier then the front.
You need to unscrew the screws in the wheelwell where the splash guard attaches to the bumper. unscrew the license plate light. Undo the 5 or so plastic clips staring at you when you open the trunk. theres also 2 on the bottom of the bumper between the exhaust cut outs or so. then you need to take off the rear lights. im assuming you dont know how to do that yet so...
remove the plastic hook things that your cargo net attaches to. they are screwed in. then pull back the plastic lining behind the lights. you may have to remove the jack panel door and jack to help. remove the harnesses and the 10mm gold-colored bolts. pull straight out.
this will reveal 1-2 black or white plastic screws under the lights. i believe it should be pretty lose by now. you can just pull on it gently and you will hear some pops but just gentle. be careful and not to scratch the paint when removing or when the bumper is off.
mods, if the CL and TL removal is different you can delete my post and disregard. hope this helps!
Meridian
Originally Posted by derrick
^ What suggestions for the TL are you referring to?
Originally Posted by rob-2
Do you have a 2nd gen? PM with your email and I can send you a scan from the shop manual.
Originally Posted by TL-Super
I need to remove front and rear as both are fubar'd. Was hoping to save some $$$ by dropping off only the bumpers at paint shop and R&R them myself
Originally Posted by fsttyms1
Hopefully they will get the paint to match that way. You really wouldnt be saving much taking them off yourself.
And I didn't mention that they would be new bumpers as both are screwed.
They'd only match by paint code on vehicle anyways wouldn't they?
EE4Life
Sep 11, 2015 10:13 PM
obsessedmotors
Sep 10, 2015 10:49 AM
Sep 4, 2015 08:03 AM
