Question about headers
Old Feb 9, 2013 | 09:36 PM
hamburglar490's Avatar
Alright well I'm looking at getting new headers. CT seems a bit out of my price range so I'm thinking about going with the redesigned DC Sports headers(HHC5528). The lowest price I'm finding is about $400. Anybody know where the best(cheapest) place to buy them is?
Also for the install, do you think I could do it myself? Like degree of difficulty out of 10?
Old Feb 9, 2013 | 09:49 PM
Karanx7's Avatar
Unregistered Member
Difficulty is pretty easy, but depends on you're experience. You got a torque wrench?
You can get a little better of a deal than that for the DC headers.
Old Feb 9, 2013 | 09:54 PM
Hmmm nope, no torque wrench. Any recommendation on a specific torque wrench? (cheap and reliable is key lol)
And am I correct in thinking that this will bolt on directly to my stock '03 TL Type S?
Old Feb 9, 2013 | 10:12 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Yes they bolt right on, you can get them cheaper I only paid 300$ for my set.
Old Feb 9, 2013 | 10:13 PM
Oh man that sounds much more appealing than $400. Where?
Old Feb 9, 2013 | 11:05 PM
I got mine from streetsideauto.com but there out of stock. Just search google, you might have to go through a few pages if not look at our vendors website.
Old Feb 9, 2013 | 11:46 PM
Alrighty I'm making some progress, so far I've found one for $350 shipped. Did you notice a big/small difference in power? Low end or high? Thanks for answering all my questions lol
Old Feb 9, 2013 | 11:49 PM
Mahusay3g's Avatar
In terms of a cheap torque wrench, buy a craftsman beam type wrench. They're 20 to 25 bucks.
Old Feb 10, 2013 | 02:41 AM
Okay so the best price I could find was $336 shipped (http://2nrparts.com/dc_sports/dc_spo.../i-130510.aspx) so I bought it there. Hoping to do the install next weekend if it arrives by then.
Anyone who's done this install before, please drop some tips here!
Old Feb 10, 2013 | 07:27 AM
Its one of the only things you can really notice a difference when you ur it on. It's good for 20-30hp at the wheels. Installation is fairly easy front and bottom is easy, the rear you have to work at but just take your time.
Old Feb 10, 2013 | 07:40 AM
MilwaukeeDave's Avatar
Buy a click type torque wrench NOT a beam type. You won't be able to see the numbers as you torque the rear header. You will need the click type.
Old Feb 10, 2013 | 09:27 AM
STGTLS's Avatar
I have the DC headers and they will make a big diff. I swear I got mine for under 300 shipped. Try eBay?
Old Feb 10, 2013 | 03:18 PM
Karanx7's Avatar
Unregistered Member
You can get a decent torque wrench for $10 at Harbor Freight.
Old Feb 10, 2013 | 05:52 PM
Front is a breeze. Rear is a pain. I'd start taking them off at the cat. Those bolts will be the most difficult to remove. There's 3 and usually due to exposure to elements and constant heat they will most likely be pretty seized. I didn't fuck around w PB Blaster, I just heated them cherry red and turned them off. Then remove the o2 sensor, you'll have best results using a line wrench or flare but wrench. Different terms but same tool. This will help avoid rounding the corners of the sensor so you can reuse it. Use some PB blaster or WD-40 on the rubber hanger then a punch or other skinny tool to slide the J pipe off. 4 bolts from header to J pipe and that's free. Next remove the headers from the heads. 5 nuts each side. Save, wipe clean, and reuse the gaskets they will be fine. You may need to remove the rear motor mount to get the rear header off. I'm not 100% sure on that part. I took mine off because I was replacing it same time as headers. Lots more room with it off. Once you're to this point you're pretty much in the clear. FOLLOW THE INSTRUCTIONS when you install new headers. You'll put one gasket and one header on only finger tight. Then other header goes on then j pipe. TORQUE the bolts as instructed. This isn't an area where "tight" is an option. Good luck, this mod is by far the one you feel most besides supercharging/turbo.
Old Feb 11, 2013 | 12:12 AM
As for raising the car to get under it, is having a lift a must? If so I'm screwed
Old Feb 12, 2013 | 05:53 PM
And will this cause issues with passing inspeciton?
Old Feb 12, 2013 | 06:15 PM
No and no.
Old Feb 13, 2013 | 11:03 AM
fsttyms1's Avatar
The best tip i can give you is, Get a good penetrating oil and start spraying ALL the bolts every night a few days before you attempt to install them. Especially the bolts that attach the Header to the cat. Those can be the most stubborn to remove.
Old Feb 13, 2013 | 11:16 AM
Thanks for all the tips guys. Just found out the headers are on backorder so I've got some time to figure all this out lol
Old Feb 13, 2013 | 11:19 AM
fsttyms1's Avatar
Check with our vendor Excelerate or Heeltoe. They may have them in stock. If they do cancel your order and order thru them. They are both great to deal with and will take care of you.
Old Feb 13, 2013 | 03:20 PM
TheMightyQuinn's Avatar
Registered Nonmember
Are you in California? If so it may fail the visual inspection.
Old Feb 13, 2013 | 03:27 PM
Pennsylvania, think it'll be okay?
And I checked Heeltoe and Excelerate, both on backorder. Guess I'll be forking out $400 on ebay
Old Feb 13, 2013 | 03:45 PM
As far as I know, only Cali has the silly visual inspection.
As for vendors, have you tried autoaccessoriesgarage or thmotorsport? thmotorsport usually has coupon codes floating around.
Old Feb 13, 2013 | 05:07 PM
I started buying parts at the right time! Headers and pulley set getting hard to find it seems. Can't wait for my next major parts I'm throwing on hopefully in a little over a month. After that I am going to start saving up for tranny failure/swap (PLEASE #2).
Old Feb 13, 2013 | 09:32 PM
http://www.racinglab.com/dc-header-c-acura-001.html
Old Feb 13, 2013 | 10:05 PM
Originally Posted by MilwaukeeDave
That's a nice price. Just emailed them asking if it's in stock
Old Feb 13, 2013 | 11:11 PM
Probably a dumb question, but on that site (racinglab) it says that it's:
Off-Road Only
CARB N/A
Please contact DC Sports for CARB detail
Is any of that going to be a problem? I'm assuming it's fine but I want to double check lol
Old Feb 14, 2013 | 12:54 AM
Gabru678's Avatar
No They usually just put that on there so they are not blamed for selling it to a Smog inspection state. Its just a loophole in the law they use in order to sell these parts. It just places the fault of ignorance on the buy and off the website incase you get in trouble (you probably never will).
You will be fine.
Old Feb 14, 2013 | 12:59 AM
You will be fine.
Ahhh okay thanks that makes sense. I'm praying there won't be any problems with inspection lol
Old Feb 14, 2013 | 01:24 PM
STGTLS's Avatar
You will have no issues
Old Feb 14, 2013 | 03:35 PM
You will have no problems. I have had them on my car for about a year. I would recommend taking them and a flash light into a dark room to inspect the welds when you get them. I had a bad set where there was a hole where they come off the block and merge together. I called the company and they sent me Abrams new set
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
DerrickW
Nov 15, 2015 05:52 PM
