HIDextra headlights
Old Feb 8, 2013 | 08:00 PM
steventrannn's Avatar
HIDextra headlights
Are all HIDextra headlight kits low beam headlights since they're powered by a ballast? I'm confused because when I looked up HIDextra kits for a 2001 Acura TL, there are only high beams available. There's and "N/A" under low beams.
Old Feb 8, 2013 | 08:13 PM
fsttyms1's Avatar
If its just your bulbs that are bad all you need are the D2r/s bulbs
http://www.hidextra.com/d2r-bulb/?sort=bestselling
Old Feb 8, 2013 | 08:19 PM
fsttyms1's Avatar
Also if you are confused, or have questions contact/call them. They will help you get exactly what you need.
Old Feb 8, 2013 | 11:41 PM
Chevelle66's Avatar
If you're ballasts are working fine, is there any benefit to getting new ones from hidextra? And is there anything you need to do to use the higher wattage ones? What's the difference between the different series, I don't see an explanation anywhere on the site.
Old Feb 9, 2013 | 11:55 AM
DanTL-S's Avatar
I kind of had a similar question about these. One of my lowbeams is REALLY bright and I love it! One of my ballasts died and i switched it for another used one, but the light doesn't match my other light. Even if the ballast is used does it still need burn time, or is it a dying ballast?
Old Feb 9, 2013 | 08:07 PM
3.2TLc's Avatar
Hey DanTL-S, were your low beam bulbs both replaced at the same time ?
If they were, try swapping the dimmer side's bulb to the opposite side.
Old Feb 10, 2013 | 12:26 PM
DanTL-S's Avatar
I need to try that, it's a little hard finding the time with work,school, and a baby. (school is 1 hour away). Know of the brand of the bulb has anything to do with it? (They're the same wattage)
Old Feb 10, 2013 | 03:04 PM
3.2TLc's Avatar
The generic bulbs are not as consistent in quality as the major brands such as Phillips or GE.
Be careful of cheap knock-offs ! The important thing is to always replace both of the bulbs as
a matched pair at the same time. That way their intensity along with lifespan will be similar.
Old Feb 10, 2013 | 03:33 PM
DanTL-S's Avatar
Yeah i actually looked at my bulbs, one is phillips and the other is some weird brand...OXy something,odd name. So the brand also has to do with their brightness?
Old Feb 11, 2013 | 07:11 AM
3.2TLc's Avatar
So, which one of them is the brightest ?
It's recommended to match them ! Better than replacing ballasts for resolving this issue.
Old Feb 11, 2013 | 11:32 AM
fsttyms1's Avatar
There is no benefit in changing the ballasts if there isnt anything wrong with them. In order to run the higher wattage bulbs you need the ballasts to go with them. Our stock ballasts are only 35w.
Old Feb 11, 2013 | 11:33 AM
fsttyms1's Avatar
Old Feb 12, 2013 | 02:28 PM
HIDXTRA's Avatar
Former Sponsor
HIDExtra Ballast Choices and Explanation
We have received a lot of customer questions asking about the difference between our ballast, so we decided to provide a post to better explain what the key differences are so you can make the proper choice.
Signature Series (35w): Standard size ballast with 35wattage going to the HID bulb.
Power Series (55w): Provides 20% more wattage to the HID bulb which provide 30-40% more brightness comparing with the 35w HID kit.
Stealth Series (35w): Slim ballast which is about half the size of a regular ballast and it is also 35w, frequently used for installation on vehicle that is more compact in the engine area for easier installation
Volt Series (35w): Our top of line HID ballast with the most advance built in component that will eliminate any issue a vehicle's computer system have with aftermarket HID. And the Canbus ballast also produces the light output (lumens) almost equivalent to 55w while only using 35w and the quality of the ballast is equivalent to OEM ballast. A very high quality HID Kit recommend for all year, make, and model vehicle.
Old Feb 12, 2013 | 05:35 PM
3.2TLc's Avatar
Thanks to HIDXTRA for the professional clarification of their available products !
This should help when deciding the appropriate HID replacement kit.
Old Feb 12, 2013 | 06:14 PM
HIDXTRA's Avatar
Former Sponsor
Old Feb 13, 2013 | 07:34 AM
3.2TLc's Avatar
Man, is that kool info or what ?
True service when needed !
Quick question.....Which model series would best satisfy our OEM "hid" replacements for overall performance and value ?
A recommendation is appreciated ! Thanks
Old Feb 13, 2013 | 09:53 AM
DanTL-S's Avatar
^ I second that! A recommendation would do justice here!
Old Feb 13, 2013 | 10:40 AM
3.2TLc's Avatar
Hey man, I think he already did that.....always the top of the line !!!!
Old Feb 13, 2013 | 11:05 AM
fsttyms1's Avatar
Awesome info.
Old Feb 13, 2013 | 12:40 PM
HIDXTRA's Avatar
Former Sponsor
For even more detailed explanation of our HIDeXtra Ballasts, visit & read this great article -- A GUIDE TO CHOOSING THE CORRECT HID BALLAST FOR YOUR HID KIT FROM HIDEXTRA
http://blog.hidextra.com/picking-hid-ballast/
Old Feb 13, 2013 | 01:23 PM
MilwaukeeDave's Avatar
Great vendor info. I love being informed about my car especially considering I know people who can't change a flat!
Old Feb 13, 2013 | 02:06 PM
AznWay's Avatar
i have HIDXTRA lights on my TL since they became AZ vendor (about 5+ years ago )
Old Feb 13, 2013 | 02:45 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Thanks for the info hid extra, I'm planning on switching to the 55 watt kit for my low and high beams later on. I would like them to be brighter. Do you have any pictures of the 55watt kit compared to 35 watt kit, light output is what I mean?
Old Feb 13, 2013 | 03:12 PM
HIDXTRA's Avatar
Former Sponsor
Hello Stephen00TL,
Thank you for your interest in our HID Products! Unfortunately we don't have the picture of the comparison of 35w & 55w right now. But we will surely work on that!
We would like to assure you since with more power and wattage..comes more output!
Old Feb 14, 2013 | 11:48 AM
HIDXTRA's Avatar
Former Sponsor
HIDExtra introduces our updated Bixenon Bulbs for 9003/H4 with enhanced light pathing for a more correct beam pattern.
If you guys are interested in what these changes are, feel free to read our blog post on this new product update here
http://blog.hidextra.com/hid-extra-a...h4-bulb-types/
Old Feb 14, 2013 | 03:54 PM
HIDXTRA's Avatar
Former Sponsor
Happy Valentines Day! We're celebrating all types of LOVE today, including your love of HID Kits. Love/Like our VDay post and reply with your best "I love HIDExtra V-Day" card, and enter for a chance to win one of the three great prize.
Prize Detail:
1st Place: Your choice of bulb and ballast type for HID kit
2nd Place: Coupon code for 50% off your entire purchase
3rd Place: Free T10 5SMD LED (pair) your pick the color!!
Winners will be announced tomorrow 5pm PST.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
