Question about climate control
Old Dec 7, 2005 | 11:02 AM
Nyses's Avatar
2k TL
Hey guys.
Was wondering about the climate control ... if you have it set to auto ...when exactly does it turn the AC on ...is it always on? I prefer not to use AC so to conserve fuel ...
Old Dec 7, 2005 | 11:35 AM
ou sig's Avatar
Boomer SOONER
it is usually on, you can check because you can hear the AC compressor turn on. I really never use the Auto because I like to control it more.
Old Dec 7, 2005 | 11:52 AM
DudeLuv's Avatar
'02blAcuRAT!! soooCool!!
Originally Posted by Nyses
Hey guys.
Push AUTO and then press the A/C button.....this will turn the compressor off (indicator will read "a/c off"). I do this most of the time when I don't need cooling (this time of the year) or defrosting the windows.
Old Dec 7, 2005 | 12:41 PM
ou sig's Avatar
Boomer SOONER
if you use any of the manual controls while the Auto fuction is on, it will turn off and go back to manual only
Old Dec 7, 2005 | 01:38 PM
DudeLuv's Avatar
Correct.....you can push a/c twice, or auto and then a/c, both will turn on the climate control (fan) without the compressor.
Old Dec 7, 2005 | 01:57 PM
ou sig's Avatar
Boomer SOONER
ya but he was talking about the AUTO function to where you set the temp and dont mess with anything else. If you push auto then go into the manual A/C controls, you will disengage the auto function.
if you have auto on, the A/C compressor will run the whole time i am pretty sure
Old Dec 7, 2005 | 02:40 PM
Nyses's Avatar
2k TL
this is what i was wondering ... so if thats the case is there a way to use auto without the ac on? or only use manual if you dont want the ac on?
Old Dec 7, 2005 | 03:08 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
It'll cycle the compressor. Sometimes when I hit "AUTO" the compressor doesn't engage, sometimes it does.
Old Dec 7, 2005 | 03:14 PM
CPR's Avatar
CPR
Climate control
According to Acura service, the A/C compressor, dis-engages, at 32*
Therefore, you should self-regulate the thermostat, by clicking off the A/C compressor.
The ONLY time it automatically comes on, is when the defrost mode is engaged
Old Dec 7, 2005 | 04:40 PM
ou sig's Avatar
Boomer SOONER
no...if you want the auto feature on, you cant adjust anything except the temp. it will adjust the proper amounts of air conditioned air, fan speed, and the actual temp. to get the in car air to your desired temperature.
you can tell if you have it on AUTO, then try to change the fan speed, or turn the AC off, the Auto light will go off turning the system back over to manual control
Old Dec 7, 2005 | 05:15 PM
fsttyms1's Avatar
The air in the winter is a good thing cause it helps prevent teh cars windows from fogging up.
Old Dec 7, 2005 | 07:10 PM
fast-tl's Avatar
I love cars!
compressor will engage only when necessary in teh auto mode. When the temp is cranked to 75 on a 40 degree day, the compressor will not run
Old Dec 7, 2005 | 08:45 PM
DudeLuv's Avatar
I'll check on that one....as far as I remember, the compressor will always cycle in "auto" or "full auto" mode (when the fan is in auto as well) regardless of the temp setting. I believe the only time the a/c will not cycle is if you then hit the a/c button in auto or full auto mode ("a/c off" displayed)..
Dec 7, 2020 05:39 PM
Rachel Lu
Sep 27, 2015 09:53 AM
Rob144
Sep 21, 2015 08:18 AM
lovic87
Sep 15, 2015 06:07 PM
PortlandRL
Sep 14, 2015 12:01 PM
