Question about climate control
2k TL
Hey guys.
Was wondering about the climate control ... if you have it set to auto ...when exactly does it turn the AC on ...is it always on? I prefer not to use AC so to conserve fuel ...
'02blAcuRAT!! soooCool!!
Originally Posted by Nyses
Hey guys.
Boomer SOONER
Originally Posted by DudeLuv
Push AUTO and then press the A/C button.....this will turn the compressor off (indicator will read "a/c off"). I do this most of the time when I don't need cooling (this time of the year) or defrosting the windows.
Originally Posted by ou sig
if you use any of the manual controls while the Auto fuction is on, it will turn off and go back to manual only
Boomer SOONER
Correct.....you can push a/c twice, or auto and then a/c, both will turn on the climate control (fan) without the compressor.
if you have auto on, the A/C compressor will run the whole time i am pretty sure
2k TL
ya but he was talking about the AUTO function to where you set the temp and dont mess with anything else. If you push auto then go into the manual A/C controls, you will disengage the auto function.
this is what i was wondering ... so if thats the case is there a way to use auto without the ac on? or only use manual if you dont want the ac on?
Climate control
According to Acura service, the A/C compressor, dis-engages, at 32*
Therefore, you should self-regulate the thermostat, by clicking off the A/C compressor.
The ONLY time it automatically comes on, is when the defrost mode is engaged
Boomer SOONER
you can tell if you have it on AUTO, then try to change the fan speed, or turn the AC off, the Auto light will go off turning the system back over to manual control
The air in the winter is a good thing cause it helps prevent teh cars windows from fogging up.
I love cars!
Originally Posted by fast-tl
compressor will engage only when necessary in teh auto mode. When the temp is cranked to 75 on a 40 degree day, the compressor will not run
