Question about alternators?
Old Nov 7, 2011 | 11:24 PM
1fast Lorinser's Avatar
I have a 1999 tl and I need an alternator and don't have much money right now to be spending to buy a new alternator so I found a used 1 from a 2003 tl ...Are they interchangeable ? or are they different?
Old Nov 8, 2011 | 06:29 AM
fsttyms1's Avatar
should work just fine
Old Nov 8, 2011 | 10:24 AM
01tl4tl's Avatar
make sure to have a parts store retest the entire system after new alt
to make sure the battery is ok
Often, one parts failure takes out the other one,,say if you drove a serious distance getting home with the charging light On (been there in other car)
a non-op alt. makes the system suck all the juice from battery- which it doesnt like at all~
Old Nov 8, 2011 | 07:48 PM
Thanks alot guys, I appreciate the help
Old Nov 8, 2011 | 11:21 PM
sammy95's Avatar
Compare part numbers? On an Acura website to see if the OEM numbers are the same, it's what I would do.
Old Nov 8, 2011 | 11:43 PM
smai's Avatar
8th Gear
i would even try an auto parts store/web site see if they come up with the same part for each year
Old Nov 9, 2011 | 08:37 AM
Rejckt's Avatar
If you decide to buy mine,
I'll let it go for $120.
Less than 500 miles on it, you'll have to transfer your pulley.
Old Nov 9, 2011 | 09:13 AM
fsttyms1's Avatar
Part numbers wont mean they wont fit. I have my 00 alt on a 2003 type-s motor. They have different part numbers but works just fine. Honda pretty much used the same alt on the J series, only difference is the amperage. If i remember right the type-s had a higher amp than the base.
Old Nov 9, 2011 | 01:48 PM
sammy95's Avatar
I meant to try that as a way, to get an idea if it would work, I mean win-win, if the numbers matched right?
But for sure they more than likely would fit.
I'm kinda picky with my car, so it has to have the part in came with from the factory.
It's also true that Acura could have superseded to another newer part number.
(I prefer less headaches when I have to diagnose something related to a wrong part number later on).
Hope you figure it out buddy.
Old Nov 13, 2011 | 08:56 PM
Thanks alot everyone for the help. I found a shop in my area that does a complete rebuild on alternators and starters and it cost about half the price of a brand new part and they can do it in 2 hrs. So if anyone needs something like this done in the queens ny area let me know. Thanks again for all your help everyone
Old Nov 14, 2011 | 09:48 AM
01tl4tl's Avatar
so what did it cost in the end??
navtool.com
31
Nov 16, 2015 08:30 PM
06TLMatt
Oct 2, 2015 08:14 PM
navtool.com
Sep 25, 2015 05:15 PM
datadr
Sep 12, 2015 09:12 PM
