Problems!
Old Jan 20, 2005 | 06:12 AM
TL_Diplomat's Avatar
booooo
Problems!
Engine light, code is P1457
SRS light, put my system in then light came on, Please help
Any help is appreciated as usual. thanks guys!
Old Jan 20, 2005 | 07:41 AM
jleon2516's Avatar
Tristate Vip Crew
DTC 1457: Leak Detected in EVAP Control System(Evap control canister system)
Old Jan 20, 2005 | 08:45 AM
69ssrscam's Avatar
2003 SSM TLS
If you just put your system in, I would bet this is a flase code. I would reset the SRS light and see if it re trips. I bet it probably is ok. Do a search on resetting the SRS light and do the paperclip reset routine....
Post back if the light stays out or not.
Old Jan 20, 2005 | 09:07 AM
fsttyms1's Avatar
make sure you get acoul-le clicks out of your gas cap when tightining it. it wasns you right on the gas cap to make sure you do or you will geta check engine light
Old Jan 20, 2005 | 08:52 PM
lbbrando's Avatar
Acura Dealer Technician
A loose cap will code a p1456 for leak tank side.
p1457 is leak canister side.
Usually the cause that I have seen is an over filled gas tank which saturates the two-way valve and bypass solenoid. If thats the case just replace these two.
Old Jan 21, 2005 | 05:03 AM
booooo
how does one go about replacing this and where can i getthe parts, how much?
Old Jan 21, 2005 | 11:58 PM
lbbrando's Avatar
The two way valve and bypass solenoid are under the car left side by rear door.
You should see a black box and small hoses and wires going twards it.
If you remove the two-way valve and bypass solenoid and fuel comes out, it was saturated and bad.
I'd say around $70 from the dealer and it comes with two sets of "o" rings.
Old Jan 22, 2005 | 05:39 AM
MikePA's Avatar
When we bought my wife's Turbo Beetle, the salesman gave us a 'tour' of the car, pointed out all the features, etc. The two service related items he stressed, because at least at this dealership, they were the most common reason people came back in for CHECK ENGINE service were; (1) People who did not tighten the gas cap and (2) People trying to nurse an extra gallon into the tank causing the problem that's the topic of this thread. His advice was to fill the tank until the nozzle shuts off the first time and quit fueling. I've been following this advice on all our vehicles ever since.
Old Sep 17, 2006 | 06:17 AM
takenaflyer's Avatar
I had a 1457 last year in my '99 TL....turned out to be the cannister was saturated (as posted above, topping off over the limit ain't a good idea). Took it to a Honda dealer (no local Acura dealer) and had it replaced because I don't like playing with gas, about $200 total. You're right, the car will run fine, but it won't pass an emissions test.
Old Sep 18, 2006 | 04:43 PM
lokee99's Avatar
I'm stock and hating it.
Its kinda funny that its on after you put a system in. Just try to reset the srs light. There was a post on how to do that through some wires and your fuse box. Try a search for srs and see if you can reset it.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
