6 1/2 solution?
Old Sep 14, 2006 | 06:29 AM
torez's Avatar
6 1/2 solution?
Hi!
Quick question... Is this gonna help out with painful installation of 6 1/2 speakers?
http://www.sonicelectronix.com/item_3690.html
Old Sep 14, 2006 | 06:48 AM
seanmcd's Avatar
On The Road
wrong forum, but if your problem is depth then those would help provided they will fit
Old Sep 14, 2006 | 01:12 PM
JMAL's Avatar
1" is a lot of space. it might then hit your door panel. i had to cut my door shell custom mount it to the old bose frame and still shave down to lower the profile of the grill it came with so that it would clear the window and keep the panel from hitting the cone. pain in the ass, but sounds great lol. i installed Focal Access speakers (pretty big)
Old Sep 14, 2006 | 01:34 PM
Billy Sacco's Avatar
Kilos of yayo in
Yeah man your door panel will probably not fit right with a 1"inch spacer. What speakers did you have in mind to use?
Old Sep 14, 2006 | 03:16 PM
torez's Avatar
http://www.sonicelectronix.com/item_4401.html
Old Sep 15, 2006 | 08:35 AM
Kilos of yayo in
Those really aren't that deep. Can't remember how much clearance there is in the door with the window rolled down but the mids I put in were almost 3" and I got away with a 1"spacer so you would probably not need anything that thick.
Old Sep 15, 2006 | 10:10 AM
torez's Avatar
Thanks, but to be sure I`ll order at least 1/2'' spancers
Old Sep 15, 2006 | 02:23 PM
Kilos of yayo in
Yeah also keep in mind depending on how big the magnet is on the speaker you may need to cut some metal to get it to fit. The stock hole is kind of wierd shaped.
Old Sep 18, 2006 | 10:15 PM
SQrules's Avatar
I put in the Kicker SS56.2 component set in mine and I used a 3/4" spacer and I had to trim a 1/2" of metal. These are just 5 1/4" speakers too. The mounting depth of my speakers is 2 11/16" and it just cleared the window when it is down.
Old Sep 18, 2006 | 10:41 PM
vtlec01's Avatar
i used 1" metra plastic spacers and they fit in the door fine with no mods (cutting, shaving) i also run the infiniti reference 6.5 components (same ones you posted a link to) and coaxels depth is perfect.
acuratl26
Apr 23, 2020 07:30 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
LoneRonin
Sep 28, 2015 09:11 AM
AcuraKidd
Sep 25, 2015 11:18 PM
DUECE_DXJ
Sep 24, 2015 04:54 PM
