problem with tires squealing
Old Jun 26, 2008 | 05:35 PM
willyfive's Avatar
when i accelerate around turns, my tires squeal like crazy. although it sounds like something normal, it seems that it happens way too easily, which decreases the control i have when i drive on curvy roads. my first thought was there was that the tires were worn out, but they all look completely fine. is there anything else i can look for or do to help this problem?
Old Jun 26, 2008 | 05:48 PM
co1063's Avatar
is your TCS on and working?
Old Jun 26, 2008 | 06:12 PM
02type-s's Avatar
-Arsenic-
Have your alignment checked and check your tire pressure.
Old Jun 26, 2008 | 06:13 PM
timmy8151's Avatar
What type of tires do you have?
Old Jun 26, 2008 | 07:23 PM
Edward'TLS's Avatar
6G TLX-S
How fast do you accelerate around turns ? You probably need some real sticky high performance summer tires to rid the squealing noise.
Try RE-01R, it doesn't squeal a tiny bit even when I take corners at frightening speeds.
Old Jun 26, 2008 | 07:44 PM
6MTUA5's Avatar
No He Can't
Slow down...
Old Jun 26, 2008 | 09:01 PM
fsttyms1's Avatar
What kind of tires? When was the last alignment preformed? And most importantly what is the air pressure in the tires?
Old Jun 27, 2008 | 09:40 AM
sb65's Avatar
If you have Michelin MXV4s, they squeal like crazy. I hated the squeal when I had them, but they do last for 60K+ (I got 80K out of one set on my Accord). I definitely noticed the MXV4s squealing in parking decks (driving at normal speeds around corners) and any time I took a turn at a remotely high speed. I never noticed any loss of control though.
Old Jun 27, 2008 | 07:21 PM
willyfive's Avatar
i do have michelin mxv4s. i just recently bought the car used, so i dont know when the last alignment was done. when i have time i am going to check the tire pressure, but it should be ok. are the RE-01R tires expensive? i cant really afford new tires at the moment, but when i do get new tires i will consider a different kind.
if the tire pressure is ok and they are still squealing, should i have an alignment performed or would it just be because of the type of tires
Old Jun 27, 2008 | 07:23 PM
willyfive's Avatar
this might be a stupid question, but how do i tell if my TCS is on and working?
Old Jun 27, 2008 | 09:08 PM
Edward'TLS's Avatar
6G TLX-S
There are tons of better tires than the MXV4's or MXM4's. Go to Tirerack.com and you'll find tires all sorted out in different categories.
The RE-01R's are expensive, but you get what you pay for -- maximum dry adhesion.
But there are lots of other tire choices between performance and price.
Old Jun 27, 2008 | 09:42 PM
I hate cars's Avatar
Tire pressure and alignment.
I've had a severely underinflated tire that would squeal at completely normal cornering speeds.
Alignment squealing issues usually show up at parking lot speeds on sharp corners.
Old Jun 27, 2008 | 10:09 PM
Midwest's Avatar
I didn't read the answers you have on this post yet, but i know the problem right at hand.
Most of the time and almost for sure that your car is off alignment. Get your car realignment and you will be OK.
It was from my experience. I got that problem, I though it was the tires, so i keep drive...then later I noticed my tires are not worn evenly. I got the car alignment then all problem resolved.
cycdaniel
Dec 17, 2019 10:58 AM
jblessing
Aug 8, 2018 09:43 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
PeterPort
Oct 14, 2015 06:19 AM
2012wagon
Sep 29, 2015 04:21 PM
