Problem stalling out (6spd) IACV ?
While driving normally on any gear, everytime as I approach a redlight or slow down drastically, I put the car into neutral. Now I normally idle at around 700-800rpms, I notice that once I step on the clutch the rpms will sometimes drop down to 200rpms or around that nature. I'm not sure if it's the IAC valve or not. Anyone one have any inputs on this?
My car was doing this after I reset ECU and immediately revved up engine after cleaning out my upper IM and EGR port, I think it learned that it was getting a lot of air right off the bat, so I disconnected battery again and let it idle for about 10 mins before starting to drive again and the problem went away. Hope this helps.
![No](https://acurazine.com/forums/images/smilies/no.gif)
My car (CLS-6 S/C'ed) does this occasionally; however, it only does it when it is extremely hot out (FL summer heat, stop/start traffic = high underhood temps.) down here.
The CLS Helms has the ECM/PCM Idle Learn Procedure:
The idle learn pricedure must be done so the ECM/PCM can learn the engine idle charateristics. Do the idle learn procedure whenever you do any of these actions:
Reset the ECM/PCM.
NOTE: Erasing DTCs with the Honda PGM Tester does not require you to do the idle learn procedure.
Remove the battery or disconnect its terminals.
Remove the ECM/PCM or disconnect its connectors.
Remove the driver's or passenger's under-dash fuse/relay box.
Remove the BATTERY (120A) fuse from the underhood fuse/relay box.
Remove the BACK-UP, ACC (40A) fuse from the under hood fuse/relay box.
Remove the No. 13 CLOCK, BACKUP (15A) fuse from the passenger's under-dash fuse/relay box.
Remove the PGM-FI main relay.
Disconnect the starter cable terminal from the underhood fuse/relay box.
Disconnect the connectors between the engine wire harness and the left engine compartment wire harness.
Disconnect the connectors between dashboard wire harness A and dashboard wire harness B.
Disconnect the ground terminals, G1, G2, G11, and G102.
To complete the idle learn procedure, do this:
1. Make sure all electrical items (A/C, audio, rear window defogger, lights, etc.,) are off.
2. Start engine, and hold it at 3,000 rpm with no load (in Park/neutral) until the radiator fan comes on, or until engine coolant temp. reaches 194f.
3. Let the engine idle for about 5 minutes with the throttle closed.
NOTE: If the radiator fan comes on, do not include its running time in the 5 minutes.
That is what the Helms (Section: Idle Control System; pg. 11-170) states; however, when I perform the idle relearn procedure, I make sure that all electrical stuff is off, start the car and let it idle through 3 fan cycles.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Also, if you are swapped, it might be a good idea to check all of the harness connections and such to make sure they are fully seated and waterproof. Just a thought.
Saw this posted on another forum...maybe it will provide some insight?
It's actually blower surge. This is caused by the supercharger's vacuum signal to the power valve not being the actual engine vacuum, but the vacuum created by the supercharger. The power valve reads the higher vacuum created by the supercharger, this vacuum closes the power valve, causing the fuel mixture to go lean, the engine then slows down due to the lean air/fuel mixture, so the vacuum signal from the supercharger causes the power valve to open as the supercharger's vacuum drops, so again the engine speeds up due to the richer air/fuel mixture, rolling from rich to lean, causing the engine to speed up and then slow down.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
SidhuSaaB
05-30-2020 12:40 AM
