Problem installing Comptech breaklines
Old May 21, 2005 | 11:34 AM
JnC's Avatar
JnC
Former Sponsor
Red face Problem installing Comptech breaklines
Sup guys, just had the local shop install comptech breaklines on the TL-S. But for some reason the breaks got worse than before, i took a test drive and the breaks were next to nothing, the paddle was very soft and was hitting the firewall when i depressed it. I had them take out the lines and put the old ones back in and the car is back to stock again. Does anyone know if I am doing anything wrong here ?? Also they did bleed all four corners after the install. Any help, would be appreciated. And also does anyone has the link to a DIY for the breaklines?
Old May 21, 2005 | 11:40 AM
fsttyms1's Avatar
sounds like they wernt blead enough or 1 of them wasnt tight and leaking a little. there is no trick behind brake lines
Old May 21, 2005 | 12:27 PM
Mr Hyde's Avatar
Yup there is no tweaking. They are either in, or they arent. If something was not tightened down properly, or if the system wasnt bled enough, it'll do exactly what you described.
Old May 21, 2005 | 12:53 PM
JnC's Avatar
JnC
Former Sponsor
Kris & Hyde, do you guys think i should have the shop apply some sort of thread sealer on the bolts before tightning them?? I was there personally when they installed the lines and as far as i know the guy tightened them pretty hard or atleast to the specified torque numbers. One more question, the kit came with 4 washers to be used with the bolt that is plugges into the actuall calipers. My question is do we need to have a washer on each side of the bolt i.e putting one washer on the bolts putting it through the line and then putting another washer on it before bolting it in the caliper . And is there any way to find out if the lines are damaged themselve? (leaking or cracked)
Old May 21, 2005 | 12:56 PM
NSXNEXT's Avatar
Just have them bleed the brakes again (or for the 1st time if they forgot).
Unless you see fluid on the ground or around the connections, they are on tight.
Old May 21, 2005 | 12:57 PM
fsttyms1's Avatar
i dont think thread sealer is necessary. if any thing i would have said they wernt bled enough. as for the washers just 1 on the bolt should be all you need (unless directions specify otherwise.) the only thing i could think of to test the lines is if the shop is capable of pressure testing the lines. id have the shop retry them and rebleed the system acouple times. if that doesnt work id say one of the lines is bad
Old May 21, 2005 | 01:00 PM
JnC's Avatar
JnC
Former Sponsor
Any of you guys have a link as to where i can find install directions of these comptech lines?
Old May 21, 2005 | 05:53 PM
tweedle99's Avatar
I've installed them before and it's pretty straight forward. Take off the old one and put the new one on. One of the line needs extra torque to tighten since it keeps sucking in air during the bleeding.
Old May 21, 2005 | 06:16 PM
fsttyms1's Avatar
if you take your wheel off and look its very straight forward and easy. just make sure its clean around the fittings to make sure no dirt gets in the line. and after its all installed you just need to bleed the brakes (bleed them very good)
Old May 21, 2005 | 06:29 PM
JnC's Avatar
JnC
Former Sponsor
I think dirt could be an issue, because i do remember the oem lines were pretty filthy once they took them off. I will have them reinstalled on monday and will make sure that they clean the surface before they put the new ones on, thanks for all the help guys. Lets see what happens on monday.
cycdaniel
Dec 17, 2019 10:58 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
k6biv
Sep 10, 2015 06:37 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
NSolace
Sep 3, 2015 08:02 PM
