Power Steering belt replacement
Old May 9, 2017 | 10:39 AM
2Quik's Avatar
I am needing to replace my power steering belt. I believe i understand how to replace it but i want to be sure i am doing correctly.
To remove the belt you loosen the pump adjusting bolt, mounting bolts and nut on the steering pump and slip off the belt.
Here is where i have the question. once the belt is on do i tighten the mounting nut and bolt down first, then tight turn and tighten the adjusting nut to get the proper tension or do i turn and tighten the adjusting nut tight first then tighten the mounting nut and bolt? any advice would be gratefully appreciated. thanks.
Old May 9, 2017 | 10:47 AM
https://acurazine.com/forums/3g-tl-p...-scans-841134/
Not for the 2nd Gen TL but similar process can be followed
Old May 9, 2017 | 11:10 AM
2Quik's Avatar
the process for the 3rd gen is different as the 3rd gen is just one belt with an auto tensioner, which is easier. The 2nd has two separate belts.
Old May 9, 2017 | 11:24 AM
doh, my mistake!
It wouldn't make sense to tighten the adjusting nut and then the mounting nut/bolt because now the tension would be different. Mounting nut first and then tension nut
Old May 9, 2017 | 11:32 AM
2Quik's Avatar
doh, my mistake!
no problem. That was my thought as well but i just wanted to make sure.
Old May 9, 2017 | 12:38 PM
SuperGreg's Avatar
Make sure you don't get it too tight. Should deflect about 1/2" when pressed with two fingers.
Drei
May 6, 2017 10:16 PM
lucky777
Jan 16, 2017 11:30 PM
bonno5id
1G CL Problems & Fixes
Nov 24, 2016 10:20 AM
dudeinaTL
Oct 28, 2016 01:03 PM
500e
3G RLX (2013+)
Oct 15, 2016 06:17 PM
