Possible AV6 problems after 10K miles
Hey guys, you probably remember all my posts towards the beginning of the year about my AV6 swap. I'm coming up on 10K now on the trans and everything has been great up until recently. I've noticed since it got cold that around 30-40 miles and hour and in 2nd and 3rd gear it jumps around. Not reving weird or anything it just feels like the trans has a rock in it that's bouncing around or something. I haven't touched the trans since it went in and it's time for a fluid flush. It was flushed with all new fluid when new. I'm just trying to figure out what's going on. I don't want another trans failure on this car in such a short time. Any ideas? Would a flush do it? Thanks guys. As always you're the best.
grab a sample of atf and send to blackstone labs with 20 dollars to be sure of whats floating around--normal or ooops!
Mr.Helpful Diagram
Try using D4 on the shifter and see if it helps.
AV6 problems....
Try a drain & fill first. Check the drain plug's magnet for fines.
If the fluid appears discolored, change the ATF filter. Ya may also want to check some of the solenoid valves or pressure switches, especially if the old ones were reused when the "AV6" was installed.
Hopefully a simple fix !!!
AV6 ..... 10k update, issues with 2>3 gears jumping
Well I did the first of 3 drain and fills yesterday and the fluid was practically black, the drain bolt was covered in shavings, and I pulled out about 4 quarts instead of the usual 3.
I'm starting to think they didn't do a drain and fill since supposedly this was new fluid 10K miles ago and now is black as night. Kind of scary some now I don't know if they actually replaced the fillets or fluid I provided. I'm gonna do another season and fill next month and check the filters. 10 bucks says they're not new anymore.
On the bright side though, my TL has never run so smooth. It snaps into every gear and runs smooth as butter.
So, now that ya did a D & F, is the tranny shifting better ?
How about what sounded like a rock bouncing around in it ?
While ya can only hope for the best at this point, I'd seriously try to get that old black fluid completely out
with the two other drains. All that burnt fluid and residual particulates will mess up the solenoids if left go.
Also, replace that old spin-on ATF filter and cut it open to see how it looks inside.
It didn't have any noises or anything it just felt like rocks in there. It was a really bad slip in the gears. And when I took out the old fluid it smelled kinda burnt. Very bad sign, I know lol. Now there's no slipping at all. Just peeved that shop stole the stuff I got them to put in the car and did a half assed job. Could've cost me a tranny.
How did the donor "AV6" tranny's fluid appear after ya got it back from the shop ?
Perhaps all they did was top off the fluid level. Did the AV6 tranny have any issues after being installed ?
If they replaced the ATF filter, it should still look new on the outside, IMO.
Consider doing the filter and another D & F sooner than 1000 miles to get that old shit out.
It's possible that the newer synthetic based DW1 fluid cleaned up the old AV6's original ZL ATF and left what ya have now, IDK ? Anyways, the stuff needs to go for your tranny's best interest at this point.
It's a positive thing that the slipping and rocks went away !!! Good luck and keep us posted.
Ok so it's been about 150-200 miles since I did the flush this past weekend. Everything was hunky dory at first but now the slipping has come back and it's affecting the other gears now too at low throttle. If I give it some gas there's no problem but without some gas it slips alot. Guess I need to invest in some more fluid and do another flush a little earlier than I wanted to. So frustrating that I'm having to do this and it was only just replaced in February.
Replace the spin-on ATF filter and try checking the solenoid screens & electrical connections.
I'll be checking the filter on my next flush this weekend. I've looked and looked and can't find a definite answer on how to get to the screens. I've been thinking about doing them for a while but I don't have any idea how to get to them. I understand the general idea just need to know (pictures and stuff) where to go to find them.
Mr.Helpful Diagram
I dont think a fluid change is going to do much but if you are going to attempt it, try a cold drain and fill.May be that the internal filter is clogged.
Does it slip while cold or hot ?
Well the biggest problem lies in the fact that it's now got 100K on the tranny and I don't know whether or not the fluid was ever changed. Only had 90K when installed and the fluid that came out looks like it had been in there for a very long time. It was black as night. Which leads me to question whether or not the filters were changed at the time of install as well. I gave them 12 quarts fluid and filters but I don't have a way of knowing (other than sight) whether they were changed or not. It slips usually while hot. The slipping didn't start until it started to get cold out this fall. It's all very confusing.
I'd at least give lkq a call. They might do something, as you're not that far out of warranty. It couldn't hurt to try. They might be prone to sell you a lower mileage one if you kick in a little more money.
Check out Honda | Acura Research, Reviews, Performance Parts, Owners - Honda-Tech.com for great pics of our tranny being torn down. Also shows solenoids.
B7WA/M7WA:have-a-look-Honda-Tech, thread # 2506110 by Transguy37
Did another drain and fill this past weekend and there's been basically no shuddering/slipping since. Plan to do another over the holiday weekend and it should eliminate any problems altogether. External filter looked good. But they may have just cleaned it outside. The fluid I'm getting out was black the first time and a dark purple the second time. There's no way clean fluid should look like this after just 10K miles. Which makes me think they probably didn't touch the internal filter. I'm also getting alot of shavings on the drain plug too. Just so lovely that I finally trusted my car to a shop since it was so damned cold out and I got the shaft. I'll keep y'all updated after the third drain and fill. On a better note I rolled 280K today!
ATF spin-on filter.......
External filter looked good. But they may have just cleaned it outside. The fluid I'm getting out was black the first time and a dark purple the second time. There's no way clean fluid should look like this after just 10K miles. I'm also getting alot of shavings on the drain plug too.
It may be a good idea to have a sample of the fluid tested to know what's in it.
Also, cut that external ATF filter open to see what's lurking within the inside.
See, that's what I had heard from fsstyms1 but I was a little weary. I would love to use the high mileage Valvoline Maxlife since it's way cheaper. Is that a pretty viable solution? Hate to keep spending twice as much on DW-1 if I don't have to. And if it means I don't need to worry about changing the internal filter then I'm more than all for it.
Honda's transmission 1st to 2nd shift feel relies heavily on OEM HONDA fluid not sure how much the MAXLIFE will affect the shifting but u can try and find out.
Evil Teo
3G MDX (2014-2020)
14
08-16-2020 04:29 AM
justin7779
12-25-2015 10:33 PM
Skirmich
09-15-2015 06:41 PM
