Phillips or OSram
Old Jul 27, 2002 | 01:00 PM
Phillips or OSram
Which bulbs come from the factory? They are theof the D2R variety correct? I'd like to keep everything as close to specs as possible to avoid warranty issues with Acura... we all know how good their customer service is
Matt
Old Jul 27, 2002 | 01:09 PM
SilverUA5's Avatar
Re: Phillips or OSram
Matt
Yes, they are D2R. I think it comes with Osram which is also the same as Sylvania, but I'm not sure what your trying to say here. Are you trying to replace the bulbs and not void the warranty??
Old Jul 27, 2002 | 01:36 PM
I want to install the 6000K bulbs.. but I have not had many good experiences with Acura's service departments.. so if anything goes wrong with the HID system.. I don't want them to have any excuse as to what made them fail... If I put the same manufacturer's bulb in.. they can't say boo! Where can I get the Osram 6000K replacement bulbs.. I have been looking all over...
Old Jul 27, 2002 | 03:00 PM
SilverUA5's Avatar
Well, you can always keep the stock D2R bulbs and if there's something wrong with the 6000K; which I doubt, you can just swap them back before you bring it back to the dealership.
Old Jul 27, 2002 | 03:26 PM
Yeah.. I guess that is a possibility... is there any benefit to Phillips vs. Osram? I notice that Osram is not as readily available as Phillips... any reason why?
Old Jul 27, 2002 | 03:30 PM
SilverUA5's Avatar
You can do a search on this topic. I'm not really sure what the differences are between the two brands, but both are well known companies. I know that Osram is a little cheaper compare to Philips.
Old Jul 27, 2002 | 07:10 PM
6ktypes's Avatar
Hella is better than all of them!
Old Jul 27, 2002 | 07:11 PM
peiqinglong's Avatar
There is no benefit to using Osram or Phillips. The bulbs are both of high quality manufacturing. But they guy I purchased my bulbs from mentioned that the Osram lasts slightly longer than the Phillips bulb. The colors are identical. If you want to get 6000k bulbs, contact Songoku on this board...he has a person in Taiwan that sells the Osram and Phillips bulbs. The Osrams are selling for $240 shipped overnight and the Phillips are selling for $268 shipped. Also the 2001 and 2002 CLs used Osram as stock, and the new 2003 uses Phillips. Keep in mind that switching your stock 4300k to 6000k, you will lose some slight visability but you gain a cooler looking color.
Old Jul 27, 2002 | 07:18 PM
fahoumh's Avatar
Shogun Assassin
Re: ...........
...based on what?
Old Jul 27, 2002 | 07:23 PM
6ktypes's Avatar
I got phillips 6000 D2S, plus I got fog light 6000 kit from Hella, I campared the 2 of them, Hella was Better, more color plus brighter! If I have a chance I will poste pics for sure.
Old Jul 27, 2002 | 09:45 PM
I have a 2003 TL-S... so I definately have the Phillips? Why did Honda change?
Old Jul 27, 2002 | 11:15 PM
I'm not sure if the the 2003 TL is different. On my CL it's Phillips. I can not say why Honda decided to change brands, but I can tell you they definitely toned down the brightness of the lights.
Old Jul 27, 2002 | 11:18 PM
Re: ...........
If you are using the projector/circular Hella fogs then the light may look brighter because of the projector style design. Take for example, BMW's headlights. From a distance they appear to be purple, but the closer you get to them, it's just a dull whitish look. The projectors always look brighter. If you want bright, just buy the D2R and stick it into your headlight and your headlights will look crazy bright.
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
truonghthe
Oct 1, 2015 03:13 AM
pistacio
Sep 26, 2015 09:45 AM
