Painting engine cover
Most car places would have it, just get a paint that can stand HIGH temperatures. I got mine at Pep Boys, they have a high selection of paint. Sand the cover with a fine sandpaper to scratch up the plastic so the paint can get into it. Then paint a few layers sanding each time with a very very very fine sandpaper (get the finest you can find) after about 4 coats it should be pretty smooth. Then spray paint some clear primer, and sand with extremely fine paper. spray until your desired gloss. Good Luck, take pics when you finish. Oh yeah, make sure the cover is dry before you sand it. I did one coat a night and left it in my shed.
http://www.acura-tl.com/forum/showth...t=engine+cover
Here's a link of my painted engine cover.
you dont need HIGH temp paint. the plastic never gets that hot. if it got that hot it would melt. and standard paint can withstand they types of temps found in the engine compartment. pick out any standard color you like and it will work
sockr1
Oct 1, 2015 01:31 AM
wusty23jd
Sep 24, 2015 11:41 AM
