oil nut socket size
Old Feb 9, 2009 | 04:24 PM
Rejckt's Avatar
oil nut socket size
16mm or 17mm?
Old Feb 9, 2009 | 04:27 PM
jjashaa's Avatar
Avant Garde Wheels
17
bowlgers's Avatar
268hp 301tq @7.8psi
17 mm
Old Feb 9, 2009 | 05:28 PM
Mista Juice's Avatar
never heard of it referred to as an "oil nut"..
as stated.. the "drain plug" is a 17mm.. and i would recommend using a closed end wrench instead of a socket to help prevent rounding off the bolt..
Old Feb 9, 2009 | 05:30 PM
JRhodes88's Avatar
Need an OEM lip kit on my
If you're calling it the "oil nut" you'd probably be best off taking it to Tires Plus.
I'm sorry...I couldn't resist commenting on a thread titled "oil nut socket size"
Old Feb 9, 2009 | 06:31 PM
fsttyms1's Avatar
A socket would be less likely to round a bolt than a box wrench (close end) Use 6 point sockets and not 12.
Old Feb 9, 2009 | 09:01 PM
in my experiences its been the other way around.. if i have to break a bolt, i prefer to have a closed end wrench because im closer to the bolt head.. with the socket you have the ability to slightly cock the ratchet to the side and cause the socket to be at a funky angle..
Old Feb 9, 2009 | 09:45 PM
fsttyms1's Avatar
Never had that happen with a socket when used properly. I have on the other hand when really having to break something free that the box wrench rounds the bolt.
Also the Drain plug should NEVER be that tight that you would round the bolt.
Old Feb 9, 2009 | 09:58 PM
twistedwedge's Avatar
6MT Someday..
I agree. I do like to use a wrench to tighten the plug though..
12 point sockets suck.
Over tightening of the drain plug can strip out the insert. The oil pan is aluminum.
Old Feb 10, 2009 | 12:55 AM
thinhthan's Avatar
17 mm
Old Feb 10, 2009 | 08:50 AM
Rejckt's Avatar
god damn, it was a simple question. I installed all my mods myself, im sure i can do an oil change. i just lost all my tools, so i gotta buy a 17mm wrench from autozone or something.
Old Feb 10, 2009 | 09:17 AM
01tl4tl's Avatar
29 foot pounds torque on the oil drain plug
I have seen many come from dealer and speedie places at well over 50-80 foot pounds ~
ready to rip the threads out of the pan!
Also see 80 ft lb spec wheel lug nuts-- set to over 130-140 because thats how tight the air gun will blast them on,
Old Feb 10, 2009 | 09:18 AM
JRhodes88's Avatar
You'd probably be better off if you bought a new ratchet set. If you're doing all the mods yourself, You're probably gonna need some different sizes than a 17 mm.
Old Feb 10, 2009 | 09:20 AM
phipark's Avatar
Not Asian
When I did my first change, I had to use some liquid wrench, closed-ended wrench and a hammer. Sucker was on there.
Old Feb 10, 2009 | 09:22 AM
acutee's Avatar
Whatever it is, it was an explanation of what he is asking for. Oil Drain Plug, the original name of itself is already wrong, so oil nut can't be worse.
Can someone define PLUG? How about earplug? Do you screw it in your ear, or do you just insert it? So, do you insert the oil drain plug or do you screw it in?
some are knowledgeable then others, but as long as you know what he is asking for, I am sure help is always appreciated.
Socket is always better for me then a box wrench.
Old Feb 10, 2009 | 09:26 AM
JRhodes88's Avatar
I had to do almost the same, I was literally pulling myself off the ground. I took it to Tiresplus just so they could break it loose and I could finish the job.
The guy was like "that was so easy to get off" as he was standing there with his air gun and my car was on the lift.
Does anyone know where to buy those nice metal screws that go into your oil pan so you can pull the lever to drain the oil?
Old Feb 10, 2009 | 09:45 AM
acutee's Avatar
Here you go, it is about $30.
https://acurazine.com/forums/showthr...ghlight=fumoto
Old Feb 10, 2009 | 09:47 AM
JRhodes88's Avatar
Originally Posted by acutee
Do you have one? I wonder if it's worth $30.
Old Feb 10, 2009 | 10:01 AM
9932's Avatar
2G wanting 3G
17 POSTS!?!?!?!
on a thread where the first post was
oil nut socket size
16mm or 17mm?
Old Feb 10, 2009 | 10:09 AM
acutee's Avatar
Other members have it, and satisfy the way it works. For convenience, I think it is worth it. I get used to the old way of removing the oil drain plug for my own reasons. If you like it, it is nice to have it installed, and make an oil change a breeze. One reason I didn't get it because our oil pan requires an extension plug for the valve to crew on as you can see on the link.
Old Feb 10, 2009 | 02:31 PM
6MT Someday..
I have one of the fumoto valves waiting on my next oil change for installation. Quality made piece.
Old Feb 12, 2009 | 06:45 PM
2000DEP's Avatar
School or Mods???
you gotta get ez oil drain valve...it's on mine and it's easy and nice...so i got one for my mom's van
Old Feb 13, 2009 | 12:25 AM
Bearcat94's Avatar
AZ Community Team
Originally Posted by 9932
17 POSTS!?!?!?!
oil nut socket size
16mm or 17mm?
Yeah. It's 17mm.
Normally called the "Oil Drain Plug", but either way it's still 17mm.
Aug 15, 2019 12:58 PM
Sep 17, 2015 08:57 PM
coykiam
Sep 11, 2015 03:43 PM
