just a question, do they replace the old tranny fuild when they work on installing the jet. an do they have to pull motor?
ChairmanMaoSaysRTFM
i believe they do replace the fluid when they put in the jet, but i had my tranny replaced entirely and they put the jet in at that time so i'm not entirely sure. and i know they don't pull the motor when they do it. i believe the remove the valvebody from the bottom of the transmission and access it that way.
someone else may know more about how they put it in though. anyone?
SSTS
SSTS
The answer is no, they don't change the transmission fluid. The oil jet is somehow installed on the top of the transmission case, so there's no need to drain the transmission. There is also no need to pull the motor or the trans. out of the car- it took the dealer about 1 hour to install mine.
fsttyms1
close
- Join DateAug 2002
- LocationAppleton WI
- Age51
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:3,068 Times in 2,123 Posts
they dont replace teh fluid when installing it. its a very easy install it just goes into the trans fluid fill hole. nothing has to be pulled to install
The New 3 Series Coupe
To me, its just a few screw and hardware... I wouldn't really call it "THE KIT"... Just trying to make it sould more... Complete.
For the first couple weeks after the install of the kit, the juggling problem seemed to persist, but now it's much smoother, the weird shifting and juggling are gone.
fsttyms1
close
- Join DateAug 2002
- Age51
it is a kit. there is more than just the jet. there is new rubber tubing and a new pipe with a "T" in it for the oil jet. there for it should be called a oil jet "Kit' Originally Posted by Inspire
To me, its just a few screw and hardware... I wouldn't really call it "THE KIT"... Just trying to make it sould more... Complete. For the first couple weeks after the install of the kit, the juggling problem seemed to persist, but now it's much smoother, the weird shifting and juggling are gone.
Quote:
Ok ok... I agree FSttyms1 always knows what he is talking about; therefore he is right... Very knowledgable individual. Originally Posted by fsttyms1
02 TL-s WDP
i'm about to get my 30,000 mile service. How do i know if the jet oil "kit" is already installed in my car or not...i bought it used last october.
And if i dont have it ...is it totally nessisary to get it installed....if so will the dealership do it for free?
thanks
thanks
fsttyms1
close
- Join DateAug 2002
- Age51
thanks
if you go to acuras site and sign up for owners link (free) it may show wether or not it has it installed. other wise you can pop the hood and look.Originally Posted by Tappy116
i'm about to get my 30,000 mile service. How do i know if the jet oil "kit" is already installed in my car or not...i bought it used last october.And if i dont have it ...is it totally nessisary to get it installed....if so will the dealership do it for free?
thanks
look just to the right of the intake pipe (the piece going from the airbox to the throttle body)
as for if its necessary i would recomend it. it protects against the major failure (even thought its very rare, youdont want it) and yes its free
fsttyms1
close
- Join DateAug 2002
- Age51
ChairmanMaoSaysRTFM
i suddenly feel concerned....i had a new tranny installed last year and when i put the tranny cooler in last week, it doesn't seem to me like the jet kit is installed at all.....curious.....let me go out and see before i get nervous.....all i know is my drain plug was alone and there was no black bar underneath it. i'm curious to see if my memory serves me right.
SSTS
SSTS
ChairmanMaoSaysRTFM
yep. nope. my second tranny is not like the one on the right. it's like the one on the left.....i take it the jet is internally installed in the new trannies?
SSTS
SSTS
fsttyms1
close
- Join DateAug 2002
- Age51
Quote:
SSTS
yes newer versions had teh jet kit internally designed. not sure when they started doing that thoughOriginally Posted by SatinSilverTypS
yep. nope. my second tranny is not like the one on the right. it's like the one on the left.....i take it the jet is internally installed in the new trannies?SSTS
