Oil Changes on a 99
Old Sep 11, 2009 | 01:42 PM
Black Tire's Avatar
99 TL, 06 E350
Oil Changes on a 99
I have had my oil changes done at the dealer since new. Now that car is over 10 years old. Do you think it would be alright to go to those quick lubes places now? Oil Changes done at dealer cost around $42 CDN, its about the same as the quick lube places. Only difference is that the quick places seem to be faster.
Old Sep 11, 2009 | 01:52 PM
hANDYcaptd's Avatar
It's the Halladay season!
Change your own oil.
I don't trust any of those shops with my car. Especially on "quick" jobs where they can get careless.
Old Sep 11, 2009 | 02:44 PM
fsttyms1's Avatar
unless you have been to them before and know they are alright id steer clear of them.
Old Sep 11, 2009 | 02:57 PM
DC3328's Avatar
Your Garage
Do it yourself man, those places advertise TEN MINUTE OIL CHANGES!!! Because it actually is that easy
Old Sep 11, 2009 | 05:56 PM
UNDEFINEDTL's Avatar
If you dont know how to change your own oil and you dont wanna learn yes you can go to the quick shops.
Old Sep 11, 2009 | 10:34 PM
Rajca's Avatar
wham bam thank you ma'am
if u go to the local quick lube shops u run a risk of them ruining ur engine. heard stories and saw it happen to a few friends. either not enough oil, no oil or they just dont change it.
Old Sep 11, 2009 | 10:42 PM
VietGuy03's Avatar
It is really easy to do it yourself! One of the most satisfying things you can do and know it is done right!
Old Sep 12, 2009 | 05:23 AM
01tl4tl's Avatar
I trust those quick shops slightly less than the dealer oil change
Both have a minimum wage person doing the job
Chances are they dont use a torque wrench to check the oil pan bolt
When you overtighten it- the most common thing to happen, then the threads get ripped out of the oil pan,,or the plug falls out while driving--thats always fun!
If you can talk to the oil tech and verify they are doing the job right-,,,,ok
Look for a small private shop that does hondas normally- at least they may care about customer relations
Old Sep 12, 2009 | 04:03 PM
cobalt107's Avatar
Some of the quick lube places do not remove drain plug, they suck out the oil. So, I do not go near them. I have heard Walmart has started doing this at their lube change locations. Do it yourself & you know it's done right.
Old Sep 12, 2009 | 05:24 PM
01tl4tl's Avatar
probably doing that to avoid the hazard of stripped drain plugs!
Vac method would be ok on a TL- not that much sludge normally if
you keep up on a cleaning program before oil change
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Thuneau
Oct 3, 2015 04:19 PM
jubikej
1G RDX Problems & Fixes
Sep 30, 2015 01:13 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
