Oil Boy
Oil Boy
i am thinking about buying an oil boy so that i can change my own oil. i don't have a flat driveway and i am not a big fan of changing my oil in the street. was wondering if anyone has used this product and what they thought of it. thanks.
:brakejob:
ive never liked them, they do a bad job of getting all the oil out... good in marine applications where you cannot access the drain plug...
why not change in the street, get some cardboard to lay on... or just change in your driveway, how slanted is it?
would getting ramps help? i know that you need to turn the wheel to acess the oil filter. are you able to turn the wheel if they are up on the ramps without it falling off?
/etc/car
thanks a lot for the info. i guess i will just spring for some ramps at autozone and call it a day. what are some precautions i should do so that they don't roll back off the ramps. ebrake and a piece of wood behind the back tires?
i change mine with out jacking the car up. its not that hard. just turn the wheel all the way to the right and you have plenty room to work
I use a mityvac oil extractor on my cars. It seriously makes the oil change much quicker, and cleaner. People have tested extractors by using them, then jacking up their car and pulling the oilpan plug to see what was left. They found that they do a great job. Some dealerships actually use extraction methods primarily on some euro cars.
On my BMW, the oil filter is in the top of the engine bay, so i dont need to jack my car up at all. On my friends RSX-S with a normal oil filter under the car, the oil change still went much quicker, and with no messy cleanup at all. We both loved using it. If you can get a quality one, Id recommend it.
Show me da MONEY
By the way I only jack my car up a little bit and turn the wheels to the right for better access to the oil pan plug and oil filter when I change my oil
IBankMouse
06-13-2020 12:53 PM
