OEM spoiler issues
Old Jan 21, 2009 | 09:36 PM
heavyjdaman's Avatar
Mostly Stock For Now
OEM spoiler issues
when i bought my car it had no spoiler, went to my bodyshop order a used one, and now i have a spoiler. few months after i got it the right side (looking from the back) started becoming loose and coming off. back to the bodyshop, bondo took care of it. few days ago went to open the trunk noticed it was coming off again. looked closer and saw the screws were stuck in the trunk but no longer attached to the spoiler.
now i know someones gonna say "dont open up the trunk from the spoiler and you wont have a problem" but i dont pick it up from there. does anyone else have this type of problem and if so any solutions?
Old Jan 21, 2009 | 09:45 PM
Gfaze's Avatar
S E L L
It sounds like they overtightened the nuts and stripped the insert for the studs on the spoiler. There's really not much you can do because the area where the inserts are placed is now damaged. You'll probably be better off finding a replacement spoiler. The bright side is that since the trunk is already drilled, you can install the spoiler yourself and avoid having some idiot over tighten the nuts.
SLushhYYY's Avatar
Keep It Simple in
^^Thats probably the problem..but if not screw the screws in lol or put some 3m Double sided tape on it. Should keep it down....
Old Jan 21, 2009 | 09:49 PM
fsttyms1's Avatar
Sounds like the "used" one was bad or the shop that put it on overtightened it. Id bring it back and see if you can get them to replace it or repair it properly
Old Jan 21, 2009 | 09:52 PM
it couldnt be that they stripped it cause after the fixed it the first time, i put it back on myself and made sure not to over tighten the screws due to that happening. as for the tape tried that too, still doesnt stick
Old Jan 21, 2009 | 10:19 PM
Allen-'s Avatar
is out, so the
I want a spoiler. lol
If you don't mind me asking, how much did you give for your used one? Came in the car's color?
Old Jan 21, 2009 | 11:49 PM
6MTUA5's Avatar
No He Can't
Due to what happening? What do you mean tape won't work?
Old Jan 22, 2009 | 01:02 AM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
what did they bondo -- the inserts back into place?
Old Jan 22, 2009 | 03:27 AM
Gfaze's Avatar
S E L L
Make sure you don't use that cheap foam crap. You have to use 3M Body Moulding tape. It's very strong and should hold the spoiler very well. It should look something like the pic below.
Old Jan 22, 2009 | 11:05 AM
$100 for the spoiler came in off white
Old Jan 22, 2009 | 11:06 AM
tyes they bondoed the inserts back in so that the screw would stick
Old Jan 22, 2009 | 11:47 AM
ഥഎണഡഏ Fellas Inc.
that might be why it broke. there is a lot of pressure that i dont think bondo around an insert would hold up against.
Old Jan 22, 2009 | 11:52 AM
NSXNEXT's Avatar
2 part epoxy ftw
Old Jan 22, 2009 | 02:17 PM
ഥഎണഡഏ Fellas Inc.
^ glue teh spoiler to the trunk (haha) or the insert to the spoiler?
Old Jan 27, 2009 | 12:32 PM
no use in using glue. whole thing is falling apart. time to search the junkyards again
Old Jan 27, 2009 | 06:42 PM
JDM Inspired's Avatar
Thumbs up
this thing really works?
Old Jan 28, 2009 | 09:00 PM
Gfaze's Avatar
S E L L
Very strong stuff. Same stuff can be used to attach car emblems like the Acura symbol or letters.
space_boy
ILX
51
Aug 15, 2017 12:06 PM
nanos
Nov 12, 2015 08:41 PM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
spoiler900
5G TLX Photograph Gallery
Sep 11, 2015 09:39 PM
MyKids&Cars
Sep 1, 2015 12:53 PM
