View Poll Results: What am i doing
Making a Dog Cage
6.05%
Making a Roll Cage
1.42%
Making a (not true) Dual Exhaust
11.74%
Making a rear mount turbo setup
17.08%
Just sitting back drinking beer doing nothing.
19.57%
Adding a turbo up front
7.47%
A supercharger
6.41%
The box contains 3.5 parts
6.76%
Time Machine
16.73%
3.7 Build
6.76%
Voters: 281. You may not vote on this poll
Now what am i up to
Old 05-25-2011, 09:18 AM
  #601
Rice Patrol
V_Langs_3.2TL's Avatar
fast, how do you intend on getting the A4 lights to fit in the 99-01 shell
I understand you can do the modifications, but wouldn't that require cutting into the hood as well? are you going to custom fab a hood?
I think it's fantastic that you have such grand ideas (I really wanna see you get that 3.5 done!) but wouldn't it look a little off?
oh and a question, is a J37 physically too big to fit in the engine bay? I know a member here has thrown in a J35, but if all you really need is a JA design engine shouldn't the displacement not matter?
That being said, I've always thought sourcing a 2004 J32A3 from an early 3G (with the 270hp) and possibly boring it a little bigger would be the best choice considering you get that awesome single piece exhaust manifold as well
but i don't know nearly as much as you do, hence the question...I mean a J37 would be godly (if not overkill) in a 2G
Old 05-25-2011, 09:29 AM
  #602
wham bam thank you ma'am
Rajca's Avatar
The 3rd gen tl engine won't fit bc of diff motor mout designs.
Hopefully u get the lights in by the meet. Really want to see how this turn out
Old 05-25-2011, 10:09 AM
  #603
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Of course cutting will most likely be required. Ill do all the necessary cutting and welding to make it flow correctly (if they fit height wise)
As for the new J37 the motor is too different to use. Im sure with the right amount of money its possible. Sticking the J37 crank into our motor however with a little work with a snout spacer works. Boring the motor out bigger really isnt an option. We dont have much to remove. That single piece exhaust manifold is shit Id rather have a nice tubular header that flows better. I want 315+ at the wheels NA which i think will be easy to do with what i am planing. Problem is is i keep flopping back and forth to possibly boosting it 3-5 psi as well which changes the build. Odds are it will be NA. I just need to find a way to tune it.
Old 05-25-2011, 10:10 AM
  #604
fsttyms1's Avatar
Thats what im gunning for. As soon as i get the light in my hand ill find out what it will take. If i can get it to fit correctly or know i can, ill order the other side and lights and ballast and get to work on the sheet metal.
Old 05-25-2011, 12:57 PM
  #605
Rice Patrol
You'll have to forgive me for not reading the entire thread, it's long and old lol. But are you planning to put a J35 into your TL? If so, my ideal setup with a J35 would be to install it, new headers and low boost. pipe dream? maybe. I'm sure you know better than I do
Wait, I always thought that the J32A3 from the '04 fit just fine into the 2G, don't most people who source an '04 6spd usually replace the J32A1/2 with that engine when they do it?
Old 05-25-2011, 01:28 PM
  #606
fsttyms1's Avatar
No, im keeping the J32A2 but putting a mix and match set of internals.
No because most doing the 6 speedswap keep the J32A2. Only those that that do a 3.5 conversion use the J35 (and some dont even use that, but use the crank for it)
Old 05-25-2011, 01:39 PM
  #607
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
Old 05-26-2011, 07:47 AM
  #608
fsttyms1's Avatar
Old 05-27-2011, 08:51 AM
  #609
fsttyms1's Avatar
Still waiting for the headlight to arrive but im taking care of some of the other stuff (thousands of rock chips) in the mean time
Old 05-27-2011, 09:43 AM
  #610
The Dumb One
Rockstar21's Avatar
no more battle scars
Old 05-27-2011, 11:03 AM
  #611
fsttyms1's Avatar
Old 05-27-2011, 12:11 PM
  #612
reese8789's Avatar
This makes me want to paint my car . Hope the head lights work out for you. Cant wait to see the finished product.
Old 05-27-2011, 01:39 PM
  #613
Always a Honda =Þ
JterrorC's Avatar
so will you be shoving this headlight in the space there and cutting around(hood,bumper and fender).... or will u take apart the housing n shoving it inside the tl light?.... probably undecided til you have it in your hands i bet... pretty anxious to see these results...
Old 05-27-2011, 02:24 PM
  #614
fsttyms1's Avatar
I will be attempting to get teh Audi light to fit in my car and do the body work around it. I need to find a wiring diag of the B8 A4 headlight though
Old 05-28-2011, 12:24 PM
  #615
Always a Honda =Þ
JterrorC's Avatar
now that u mention the wiring...arent those headlight controlled by a ecu? ill ask my euro luvin friends..
Old 05-28-2011, 03:13 PM
  #616
fsttyms1's Avatar
Yea, I don't need all the special functions they do just what wires do what.
Old 05-28-2011, 03:14 PM
  #617
fsttyms1's Avatar
Old 05-28-2011, 03:15 PM
  #618
fsttyms1's Avatar
Sorry for the crappy pic. I'm not home and those were sent to ne by a friend. I couldn't wait any longer to see them by the car
Old 05-29-2011, 12:44 AM
  #619
Rice Patrol
hmmm seems like it just might work =)
are those the LED ones or the base model lights?
Old 05-29-2011, 05:49 AM
  #620
fsttyms1's Avatar
led
Old 05-29-2011, 10:41 AM
  #621
fsttyms1's Avatar
I had a few minutes to trim some metal
should be able to get it to work
Old 05-29-2011, 05:49 PM
  #622
Rajca's Avatar
gonna look sick when its done
Old 05-29-2011, 06:36 PM
  #623
Unregistered Member
Karanx7's Avatar
That's gonna be some serious work...
GL with the fender. Looks like you're going to have to close it up somehow.
Old 05-29-2011, 07:19 PM
  #624
fsttyms1's Avatar
That's what my welded is for. Already have some plastic weld for the bumper too :2cool:
No.turning back now, removed too much metal.
Old 05-29-2011, 07:23 PM
  #625
fsttyms1's Avatar
And there is more removed from what you see here
Old 05-29-2011, 07:30 PM
  #626
crazyasiantl's Avatar
Old 05-29-2011, 10:52 PM
  #627
MechEng
03tLsNBP's Avatar
oh wow
Old 05-30-2011, 09:24 AM
  #628
fsttyms1's Avatar
I just ordered the other Headlight, that's how confident I am now I need the ballasts and the plug for each Headlight. I have less than 2 weeks to get this dun for the Acura meet.
Old 05-30-2011, 10:35 AM
  #629
MechEng
03tLsNBP's Avatar
good luck! you have a lot of work ahead of you!
Old 05-30-2011, 10:45 PM
  #630
AM Flakes still Drippin'
HosTL Moderation's Avatar
Very nice, can't wait. Dopeness in the process
Old 05-31-2011, 07:49 AM
  #631
fsttyms1's Avatar
Nah, Body work and modification are what im good at. Still looking for the wiring and the main harness to plug into the headlights
Old 05-31-2011, 08:00 AM
  #632
Coal
05TLdcc's Avatar
this thread sucks
Old 05-31-2011, 08:11 AM
  #633
fsttyms1's Avatar
Originally Posted by 05TLdcc
this thread sucks
You have been reported
Old 05-31-2011, 08:15 AM
  #634
Coal
05TLdcc's Avatar
Old 05-31-2011, 10:11 AM
  #635
Old 05-31-2011, 11:08 AM
  #636
Flipster23's Avatar
Old 06-02-2011, 12:38 AM
  #637
Always a Honda =Þ
JterrorC's Avatar
... nah..jk... take your time..lol..
Old 06-02-2011, 07:32 AM
  #638
fsttyms1's Avatar
Ordered the mounting trays for the headlights, they will be here tomorrow along with the HID ballasts and the Led Ballasts. Figured out all the wiring EXCEPT for 2 wires. A Red one and a Blue one that go to the LED Ballast. The guys on Audizine havent been much help Anyone have access to the audi service manual??????
Old 06-02-2011, 07:33 AM
  #639
fsttyms1's Avatar
The car gets parked till its finished starting tomorrow. Ill have 8 days to finish in time for the meet. I wont recieve the other headlight till monday Hope im good at making templates and fabrication
Old 06-03-2011, 10:27 AM
  #640
Rice Patrol
good luck!!!
Quick Reply: Now what am i up to
