NOS: Is anybody running it ???
Old Aug 23, 2007 | 08:46 PM
1osunut's Avatar
I would like to know if anybody out there has nitrous oxide on their TL-S. I have a 2002 TL-S that I take to shows and I have picked up a system that will be installed on the car over the winter. The plan is to basically use it for looks - but it will be fully fuctional. The bottle will be painted WDP to match the car and engine covers and will be mounted on a polished billet mount. The bottle will have a chrome liquid filled gauge on it and the purge will come out from behind the Acura logo in the grille.
I have talked to several performance shops and they all say if I keep the system at 50hp or lower that it waill be perfectly safe. The plan is to put a NOS switch umder the gas pedal that will only activate when the pedal is at WOT and the system is armed. Im not sure how often I would ever use it but it should turn some heads and look really nice in the trunk.
I just want to know if anybody else is running a system, what brand, how its installed and how the performance is. I'm guessing a 50hp shot along with the mods I already have should make the sedan scoot pretty good. Thanks in advance.
Old Aug 23, 2007 | 08:50 PM
fsttyms1's Avatar
I know there are members out there running Nitrous and more than 50 shots. Try a search
Old Aug 23, 2007 | 09:02 PM
orgnlprankster7's Avatar
08 Civic SI
DIRTYJOHN has his tl-p running 12s on 75 shot if im not mistaken, look in the race and comp section he has many posts with vids prooving it.
Old Aug 23, 2007 | 09:16 PM
Rajca's Avatar
wham bam thank you ma'am
im running a 75 shot with colder spark plugs. i talked to a couple of performance shops also and they said that a 75 shot would be the most that they would recommend on a stock engine. i have a zex kit which u tap into the TPS and u dont need to mount a switch under the gas pedal all u do is program it.
Old Aug 23, 2007 | 11:16 PM
mcflyguy24's Avatar
DIRTYJOHN also has a built motor. He's a bit crazy, and I still haven't seen any pics of his car, just video. Someone else on here with a NGP TL-S I think had 100 shot NOS on there ride too.
Old Aug 23, 2007 | 11:22 PM
AMGala's Avatar
Lamborghini Aventador FTW
Pizaul either has NOS or is going to have it soon.
Old Aug 24, 2007 | 05:28 AM
02TLSfan's Avatar
Prick of the month
Are you anywhere near the Columbus/Easton area? I'm going to be visiting my mom up there sometime soon and I'd like to check out your ride if you're nearby.
Old Aug 24, 2007 | 05:48 AM
1osunut's Avatar
You are more then welcome to check it out but I'm 2hrs North in Cleveland.
Old Aug 24, 2007 | 11:23 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
If you go for a quality setup/installation to be used wisely, i think you shouldnt have problems running a 75 shot.
Specmiata82
Sep 30, 2015 10:04 AM
NorthWestAnimal
Sep 28, 2015 06:20 PM
MikeJM310
Sep 24, 2015 07:24 PM
