Noise backing up
Old 05-02-2001, 10:24 AM
FlyingPig's Avatar
Post Noise backing up
80% of the time, when the car sits there for a few minutes or longer, I get a weird noise when I back up.
This happens quite often coz I have to back out of the driveway and parking lot all the time. It sounds like it's from the rear (right hand side even) and the sound is between rubbing and grinding. It's louder than rubbing and not as sharp as grinding.
It happens about 1 sec after moving in reverse and lasts quite long at around 1 second.
Anyone else has this problem?
Old 05-02-2001, 10:46 AM
Talking
Nope. Sorry to hear that you have this problem. Did you bring to the dealer to have it check?
2002 Acura TL Type S
Nighthawk Black Pearl
Parchment Leather
Old 05-02-2001, 10:47 AM
Guest
Guest
Posts: n/a
Post
Sounds like thats the antilocks kicking in. I think it is like a test procedure. I think as long as your breaks are working fine I would not worry. You do not hear any noise while your driving right. If you did then I would go get it checked out.
2000 Acura TL
Silver
fog lights, tints, burlwood shift knob,
sunroof visor, 17in Mille Miglia sports
H&R springs, ingals camber kit, Soundstream 405 amp powering 2
JL Audio 10's and Infinity tweets.
Old 05-02-2001, 10:50 AM
mmski1's Avatar
Post
Maybe it is the auto tilt on the passenger side mirror.
Old 05-02-2001, 10:53 AM
3.2-TL's Avatar
Post
I had the same problems.
Old 05-02-2001, 12:17 PM
imax's Avatar
Post
I have had a '99 3.2Tl and now my new 3.2TL-S and neither has exhibited what you describe.
'02 TL-S Satin Silver
Old 05-02-2001, 12:22 PM
AZ O.G NoOldManVetteOwner
2K2SilverTL-S's Avatar
Post
For those of you who dont know already.....putting the power mirror setting in-between the left and right side mirror adjuster causes your right side power mirror to tilt down when you put the car in reverse, hence causing a buzzing noise....i bet you what your hearing is the mirror tilt....check it out
Old 05-02-2001, 12:33 PM
imax's Avatar
Post
My right side driver mirror auto-tilts when I put the TL-S in reverse and there is NOT any unusual sound. In fact I hear nothing!
'02 TL Type-S Satin Silver
Old 05-02-2001, 03:46 PM
MCD
MCD's Avatar
Post
According to various members, there is a slight buzzing noise after you put it in gear where the ABS systems performs a self-test.
Mine does this, usually twice, after I first put it in gear.
Wayneg, can you confirm?
2002 Acura TL-S w/ Navi
Aegean Blue
Underbody kit
Spoiler
Former: 1997 Acura Integra GS-R (Pioneer Head Unit, CD-Changer, EQ, Boston Acoustics separates, 2 - JL 12W4s, Kicker & Pioneer Amps)
Old 05-02-2001, 04:57 PM
FlyingPig's Avatar
Post
It's not a buzzing noise. It's much louder than that buzzing noise when the mirror goes down.
It also happens after you backed up at least 4 or 5 feet. It only happens when I back up.
It feels and sounds like the caliper did not let go for a second. But that shouldn't be the case, otherwise I would hear that from the start not 4-5 feet after start backing up.
Old 05-02-2001, 11:15 PM
FlyingPig's Avatar
Post
If it's auto tilt, it would be 100%?
I'm not sure what it is yet.
Unless I can reproduce at well, the dealer would have an excuse not to fix it.
Old 05-02-2001, 11:36 PM
greenpelikan's Avatar
Post
Every morning when I pull out of my garage I hear a buzzing noise when I first let the go move forward. It lasts about a second or two. I have experienced this in my '99 and my '02. I think its normal.
Old 05-07-2001, 09:00 AM
thephantom's Avatar
Post
CONFIRMED! I heard that noise and I brought it to the dealer and before I even put the car in gear to reproduce the noice, the mechanic told me what MCD had posted.
Those who know, don't talk.
Old 05-07-2001, 02:07 PM
Post
Yep, Same here it happens twice once after starting, after putting in reverse then once usually after putting it back in drive. To add a third noise, there is a rubbing squeak (like rubber to metal) that happens the first time backing it up for the day???
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by bricot on May 07, 2001 @ ]</font>
Old 05-07-2001, 02:19 PM
thephantom's Avatar
Post
Can't say I have the third, I hope I don't have the third noise.
02-25-2020 09:57 AM
iCrap
09-11-2015 06:21 PM
Mike Bertram
09-10-2015 09:27 AM
Steven Vitek
ILX
09-10-2015 07:29 AM
dlknight
09-03-2015 07:54 PM
Quick Reply: Noise backing up
