No TCS off button with TL-S
Guest
Posts: n/a
I test drove the new blue one (it's an awesome color in person -- the pics here don't do much justice)
I noticed that there is no way to turn TCS off (as on the current TLs)
Also, my dealer says that if you want nav it will be another month before you can get the TL-S with nav, is this really true?
there is a button in the same place as TL(tsc) to turn of VSA and that also disables the traction control, its part of the same system... i actually made sure that VSA worked and turned it off a couple of times during the test drive... it works
and yes, the NAV vesion is already in, the dealership i was at had two nav, two non-nav tl-s's in stock
Aem Short Ram / Comptech Sway Bars / Comptech Springs / Custom Cross-Drilled Rotors / Pirelli SP7000 Tires
Alpine CVA-1005 Head Unit / Alpine G320 EQ / Alpine DVA-5205 DVD / Alpine NVE-N851A Navi / JL Audio XR653-CS 3-Way comps for the front powered by a bridged Alpine MRV-F407 amp / Boston Acoustics 5.5 ProSeries 2-Way comps for the rear powered by Alpine MRV-1002 amp / Dual 10" JL Audio W-6 sub powered by Alpine MRV-1005 amp / Two Alpine CHA-1214 CD Changers
Pics of my TL and Fun/Crazy Pics
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by oracion on March 18, 2001 @ ]</font>
2000 Naples Gold 3.2TL/Navi - Factory Stock but with up-graded tires
Guest
Posts: n/a
Originally posted by hagerc1:
According to the 02 manual, there's no TCS on the TL-S. That'd make sense why no button would exist to turn it off. TCS is, however, on the base model TL.
--Why does Acura keep shafting the TL owners?
The CL had many of the 'new' TL-S features a year ago!
Is this really the case -- the TL Type-S has no TCS?
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by GoldnTL on March 18, 2001 @ ]</font>
Read the above posts. The TL has VSA which encorporates the TCS and adds more stability during turns to prevent loss of control. It can be turned off. This is the same thing that the CL-S has. And trust me it works. Whle driving the TL-S I floored it from a light and the wheelspin was brought in check by the VSA, and a flashing exclamation point light lights up in the dash to let you know you dont have 100% traction
Just call me..................Mr Hyde
TL Type-S Moderator
02 Aegean Blue TL Type-S with Navi(on the way)
Accord Forum Moderator/Honda-Acura.net
96 Sherwood Green Accord EX
TL Type-S Moderator
I'VE BEEN DRIVING IN SNOW!!!
It works -- it all works.. BEAUTIFULLY.
Trust me -- whatever you want to make of the mumbo jumbo in the brochures, the websites... trust me, after having driving in about two inches of snow and slush, the VSC and it's INCORPORATED traction system works well!
Furthermore, now that it's near 50 degrees and I've been driving the car on dry roads -- I also know that the VSC does wonder to bring the slipping wheels **during hard accelerations** in check without.. WITHOUT compromising speed! However, better tires like Potenza RE930's would TRULY BENEFIT THIS CAR'S PERFORMANCE -- straightline performance as well as cornering!
It's all good fellas.. it's all golden.
2002 TL Type S
White Diamond Pearl
Parchment
2002 TL Type S
White Diamond Pearl
Parchment
MetalGearTypeS
Aug 29, 2016 08:28 PM
soupi
14
Nov 15, 2015 11:15 AM
