No idea, someone help...
Old Oct 28, 2008 | 02:27 AM
nayaab88's Avatar
I'm hearing this whining/whistling sound when i'm driving. Its gets higher as the rpm goes up. Kinda sounds like a turbo spooling up or sumthin but its not as loud. I can only hear it with the windows up and and no music on. The car drives perfect so far, thank God. Anything i need to be worried about?
Old Oct 28, 2008 | 02:37 AM
azn_xxxd's Avatar
.a BUM with SMG...
Maybe some leak on intake man, i see you removed the intake resonator, check that or it mighbe the exhaust or something. But try to tight up the intake first and see if it solves the problem
Old Oct 28, 2008 | 04:53 AM
Rajca's Avatar
wham bam thank you ma'am
when my trans started to slip it would make a super chareged like whine. also same thing happened to my buddy
Old Oct 28, 2008 | 11:01 AM
EL19's Avatar
If its with no music on its probably engine interference. Is it coming out of the speakers?
Old Oct 28, 2008 | 11:05 AM
9932's Avatar
2G wanting 3G
did you upgrade your audio system recently?
Old Oct 28, 2008 | 12:53 PM
Acura_VA20's Avatar
Hmm wheel bearing maybe??
My car makes a noise as well, sound goes up with higher speed.
Old Oct 28, 2008 | 02:09 PM
fsttyms1's Avatar
Wheel bearing or trans.
Old Oct 28, 2008 | 05:29 PM
nayaab88's Avatar
i just remembered that when i replaced my air filter i came across a stubborn screw so i had to cut the plastic around it to remove the cover and now it might not be sitting all the way. maybe it could be that. also, the tranny was replaced in 2005.
Old Oct 28, 2008 | 07:43 PM
Rajca's Avatar
u might not have a tight seal so u have an air leak
Old Oct 28, 2008 | 09:13 PM
jayunsplanet's Avatar
I've read that others with CAI's have a whistle at like 3k rpm for a second before a shift. I know I do. If you feather the throttle just right you can keep it whistling for a while. I know you don't have a CAI, but you do have an intake mod that removes the resonator which could prevent a sound like that. Might not be your issue, just throwing that out there for you.
Old Oct 28, 2008 | 11:01 PM
CL-Slick's Avatar
Chillin' in my trailer
When the A/C is on in my CL and I accelerate, there is a slight whistle heard. Try turning off the A/C and try it.
08KBP_VA
Oct 22, 2019 01:55 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
Gout
Nov 2, 2015 12:22 AM
Houston
Oct 8, 2015 01:27 AM
