No dome or map lights, help
I was messing with my dome light to fix a rattle. I put some dynamat behind it and since it was the extreme dynamat I think I shorted something out since it has a foil backing on it. Now my dome light and my map lights dont come on. I ran through all the fuses behind the fuse panal and under the hood that I could find. THey all checked out ok. What else could it be?
Originally Posted by LukeaTron
Might you have accidentally disconnected something in the process? Perhaps while pulling on a wire you pulled a boot apart.
Originally Posted by ed'sTL
did you try the fuse box thats on the passenger side of the dash? try those fuses. I had that happen to me although my door lights didn't work either.
Originally Posted by probmxstyle
Wow thanks for the reminder. I completely forgot that fuse panel was over there.
Yeah definitely check those fuses. The fuse for the interior lights is in there. You’re welcome.
rockyboy
Aug 4, 2024 10:35 AM
cycdaniel
Dec 17, 2019 10:58 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
rockyboy
Jan 25, 2016 06:00 PM
