No dome or map lights, help
Old Feb 20, 2008 | 11:25 AM
probmxstyle's Avatar
I was messing with my dome light to fix a rattle. I put some dynamat behind it and since it was the extreme dynamat I think I shorted something out since it has a foil backing on it. Now my dome light and my map lights dont come on. I ran through all the fuses behind the fuse panal and under the hood that I could find. THey all checked out ok. What else could it be?
Old Feb 20, 2008 | 11:35 AM
LukeaTron's Avatar
Might you have accidentally disconnected something in the process? Perhaps while pulling on a wire you pulled a boot apart.
Old Feb 20, 2008 | 11:40 AM
I dont think that could be it, all i did was unbolt the domelight and let it dangle. I didnt pull on it real hard or anything.
Old Feb 20, 2008 | 12:23 PM
ed'sTL's Avatar
did you try the fuse box thats on the passenger side of the dash? try those fuses. I had that happen to me although my door lights didn't work either.
Old Feb 20, 2008 | 01:16 PM
kushsmoker's Avatar
B A N N E D
yea check your fuses
Old Feb 20, 2008 | 01:33 PM
Wow thanks for the reminder. I completely forgot that fuse panel was over there.
Old Feb 20, 2008 | 02:55 PM
ed'sTL's Avatar
Yeah definitely check those fuses. The fuse for the interior lights is in there. You’re welcome.
rockyboy
Aug 4, 2024 10:35 AM
cycdaniel
Dec 17, 2019 10:58 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
