new instrument cluster
You dont need to replace the whole cluster.
you have a few ways of doing it.
What gauges are screwed up?
Or you can buy just the gauge assembly itself and insert it without having to mess with the needles.
#6,7,8
#6,7,8
Your NOT supposed to pull the needles off.
Install the cluster with the cover off, find a friend with a car or a GPS and go out to a back road. Get the car up to a predetermined speed (needle off) set the cruise to hold at a constant speed and place the needle on where it should be. Test with different speeds to make sure its accurate.
OR
Buy just the speedo gauge itself from the link. Its very easy to install (found under meter components)
http://www.acuraautomotiveparts.org/...catdisplay.jsp
OR
09-15-2015 06:44 PM
