New Guy With a Brake Question...
Old Feb 12, 2012 | 09:31 PM
MSG C5's Avatar
I've been reading the forum for a few days and just registered. I pretty much agree that the OEM Acura brake rotors are pretty bad, so I'm going to try a set of Napa Ultra Premium rotors for the front.
My question is what about the back rotors? You know when the front rotors are warped, i.e. steering wheel shake, pulsating stops, etc., however what about the rear rotors?
Any signs to look out for?
Thanks!
Old Feb 12, 2012 | 09:34 PM
MSG C5's Avatar
Thanks!
BTW - It's a 2002 Type S.
Old Feb 12, 2012 | 09:38 PM
mY sLOW UA6's Avatar
I'm pretty sure you get a pulsing if the rears are warped too.
Old Feb 13, 2012 | 12:01 AM
gen2gsr's Avatar
same thing for the rear just went through this on my car.
Old Feb 13, 2012 | 12:26 AM
01tl4tl's Avatar
an 02 is probably on its 2nd set of rear pads,,and the rear rotors are so cheap,
You may as well replace them now
DO: FLUSH the brake fluid before doing the rest of the brake work
that prevents backwasahing of crud into the main lines,
then back out again during flush afterwards
should change brake fluid every 1-3 years
special TL bleed order is LF RF RR LR
please see our brake diy for more help
Old Feb 13, 2012 | 08:18 PM
MSG C5's Avatar
Thanks for the information! Thinking Napa Ultra Premium rotors.
Old Feb 14, 2012 | 05:08 AM
DOHC TL's Avatar
Napa.... yup thats what i got
Old Feb 14, 2012 | 08:57 AM
VTEC11's Avatar
Thanks!
Steering wheel won't pulsate if the rears are warped but the rest of the car will. You will definitely feel it through the seat.
Old Feb 14, 2012 | 04:31 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
You can also chack the black market in the sponsored/group sales section. Some of the vendors have packages you can get from heeltoe or excelerate performance and other companies to.
Old Feb 19, 2012 | 12:26 PM
MSG C5's Avatar
I completed the work yesterday...
I installed four new Michelin Primacy MXV4 tires (replaced the dealer-installed Michelin Pilot MXM4s) and had them balanced and aligned. The front passenger tire was off.
I also installed new rotors and pads all around and flushed/installed new brake fluid. I went with the Napa Reactive One Ultra Premium rotors in the front and the Napa Ultra Premium rotors in the back. I also installed the Napa ceramic pads.
The original front OEM rotors lasted 140K miles, however they were resurfaced twice. The second set of OEM front rotors were installed and only lasted 6K miles before they began to warp and needed to be resurfaced.
The car now has 180K miles and drives like it's brand new. Hopefully these Napa rotors will perform better than the OEM rotors.
Old Feb 19, 2012 | 08:54 PM
01tl4tl's Avatar
bed them in per makers instructions, and they will outperform and outlast the oe by far!
Old Feb 21, 2012 | 03:44 PM
shakenbake73's Avatar
8th Gear
Old Mar 4, 2012 | 08:23 PM
sl33kTL's Avatar
EBC Slotted or Dimpled rotors ftw
mada51589
Jan 9, 2025 04:40 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
nuldabz
Sep 3, 2015 05:49 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
