Need Some IDEAS!!!
I'm stock and hating it.
Need Some IDEAS!!!
Okay I have an 00 TL-P. What im trying to do is run the Navigation antenna to the back part of my roof. I tried running along the rear widow molding but it is too tight around the top of the window to hold it in. I was thinking of using some clear silicon to hold it in but if there is a cleaner better way please advise. Thanx for the help in advance.
Run it along the southern route... pull up the door sills and run it along the floor carpet and then up the C-pillar to the roof.
If not, pull the trim off from around the sunroof and unscrew the dome lights. You should have enough clearance to run the wires under the headliner then.
Originally Posted by mezzerTL-S
the unit and subscription where a Christmas gift and I mounted the unit myself with it hardwired to the map light feed...
this is where I installed the antenna
saw this and remembered this thread asking where to put the antenna
