Need Key Fob Casing
2000 Acura TL NGM
Need Key Fob Casing
Hey i got one remote key fob and unfortunately the damn casing broke right where the key is attached. all the electronics still work but im scared to death that i'm gonna lose the key or the remote anyone know where i can get just the casing or do i have to by a new remote from ebay and swap out the electronics.
not sure about buying just the case, although i doubt it is possible unless you find that on ebay. but why switch the electronics if you did buy a new one, it could just be reprogrammed with much less hassle.
2000 Acura TL NGM
about getting it reprogrammed i dont want to do it because i heard it cost a lot and only the dealer can do it. btw by switching ou the electronics i jus mean popping the old circuit board into the new one...would take 1 min maX\x.
Make sure the codes in the back of the new remote matches your old stock remote. Some key fob may look the same
but won't work with each other. Be sure to have all Key fobs you want working with you when you do this.
Its VERY important to stay within the time limits or it wont work
1. Turn the ignition switch ON (II).
2 Within 1-4 seconds push the transmitter lock or the unlock button.
3 Within 1-4 seconds turn the ignition switch OFF
4 Within 1-4 seconds turn the ignition switch ON (II).
5 Within 1-4 seconds push the transmitter lock or the unlock buttin.
6. Within 1-4 seconds turn the ignition switch OFF.
7. Within 1-4 seconds turn the ignition switch ON (II).
8. Within 1-4 seconds push the transmitter lock or the unlock button.
9. Within 1-4 seconds turn the ignition switch OFF.
10. Within 1-4 seconds turn the ignition switch ON (II).
11. Within 1-4 seconds push the transmitter lock or the unlock button.
12. Confirm you can hear the sound on the door lock actuators. Within 1-4 seconds, push the transmittor lock or
onlock button again.
13. Within 10 sec, aim the transmitters whos codes you want to store at the receiver, and press the transmitter
lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter
code is stores. Make sure you program all transmitters you want working within 10 seconds of each other.
Ones not included in this programming will no longer work.
14. Turn the ignition switch OFF, and pull out the key
15. Confirm proper operation with the new codes.
And just so that some dont think i pulled this out of my arse
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
![](http://photos.imageevent.com/shawnsef/helmscans/01.jpg)
T-Swzy
thanks for the instructions...its great when ifind someone who knows what there talking about. now i just got to order the keyfob
Originally Posted by burnerjunky
wheres the keyless reciever unit
Received 1,080 Likes
Originally Posted by Razzi
kris is always around, all he needs now is a cape and a leotard
Kris needs to get a real job like the rest of us.
Nah, I'm just jealous.
![Sad](https://acurazine.com/forums/images/smilies/sad.gif)
Wish it was dropped.....
yankeeman515......answer your pm and you will get a fob shipped to you!!! i have extra. ill give it to ya no cost, just reimburse shipping cost!!!
Originally Posted by mge2790
im looking for a key fob too if you have another one
wow im feeling awful nice today.....
i went to my local acura and honda dealership and saw exactly what you need. its a leather sleeve that goes over the remote and has a key ring on it. in fact one of the it shows that you can use it if you break the remote where the keyring goes, which is what i think you did. they go for about 10-12 dollars. maybe you should swing by your dealership to see if they have something similar to that for sale.
Originally Posted by NSXNEXT
Kris needs to get a real job like the rest of us. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Nah, I'm just jealous.![Sad](https://acurazine.com/forums/images/smilies/sad.gif)
for some reason its not letting me send you a pm, it just says im not authorized to do that. im guessing i dont have enough posts, so your going to have to pm me i think, hopefully i can reply.
Originally Posted by jnavedo
I just reprogramed my remote with the instructions that fsttyms1 provided and it worked just as stated. Thanks.
Over Caffeinated
Question on Fob #1 vs #2
I've ended up with two #1s. The vendor I got the 2nd #1 from INSISTS the numbers matter not, it's the sequence that they are programmed in that matters.
I did program my 2nd #1, and it works but as 'driver one'.
Can anyone confirm that it really does not matter about the numbers on the fobs? That if I reprogram my first #1 and then my 2nd #1 that I'll have driver 1 and driver 2?
After dinking with the remotes, I'm thinking the vendor is FOS, but hey, I'm a NOOB with Acuras - but I LOVE my TL!
Thanks for any insight anyone can provide!
Steve
Steve
soupi
14
11-15-2015 11:15 AM
