Moonroof visor
Old Apr 24, 2001 | 01:35 PM
TLinKC's Avatar
Daddy
Post Moonroof visor
For those of you with the moonroof visor, how difficult is it to install and remove? Do you remove it every time you wash your car? If not every time you wash your car, how frequently?
'00 Firepepper Red TL
Old Apr 24, 2001 | 05:28 PM
adamyankee's Avatar
Exclamation
I have never removed it. I believe it is bolted through the roof so there would be holes.
Old Apr 24, 2001 | 05:34 PM
TLinKC's Avatar
Daddy
Post
Are you yanking my chain? There is NO WAY I would let them put holes in a roof for a sunroof visor. I gotta believe that there is another way to install. Other sunroof visors attach to the edge of the sunroof.
Old Apr 24, 2001 | 05:42 PM
adamyankee's Avatar
Post
DOH!!
My bad, I never really saw the brackets that attach under the moonroof trim.
Old Apr 24, 2001 | 05:46 PM
Post
You guys crack me up!
The moonroof visor is held on by two clips. It can be removed anytime. The only thing that stays on the car is two really small pieces of vinyl tape (clear) that keep the brackets from rubbing directly on the paint. the tape is hidden when the visor is on, and barely noticable if you look for it when the visor is off. Mine came off in a touchless car wash, so I dont use it anymore.
1999 Satin Silver TL Dunlop SP9000 215-45/17-mounted on CL-S 17" Rims
H&R Springs-Axiss MetalMasterPads-Crossdrilled Rotors
-Inspire Tailights-20/30/40 tint
2000 S2000 Honda Roadster
- Mingster Aeroscreen, Smokin Front mesh Grill, Clear Sidemarkers...
Old Apr 24, 2001 | 06:02 PM
Mr Hyde's Avatar
Post
Yup the install is painless, no drilling required. The only thing is that if you keep it on for a while without ever taking it off, dirt and sand can get under it and essentially sand away the paint in the area that the visor touches the paint. This happened on my last Accord with the OEM visor. When I wanted to take the visor off, I really didnt want to leave it off since the paint in the contact areas was so bad.
If you are getting one I would recommend getting a strip of the X-pel stuff used for the clear bras and cutting a piece to match the curve of the visor and putting that in between the visor and the paint. If not that then at least several good coats of wax applied every now and then when you wash the car in case you ever want to get rid of the visor.
Install and removing involves two screws thats it.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by Mr Hyde on April 24, 2001 @ ]</font>
Old Apr 24, 2001 | 06:53 PM
FTM-1's Avatar
Post
Had a visor on my 94 Accord with no problems.
It was factory & was put on the car when I purchased it new. I had the car until I got my TL in late 99. So for 6yrs no problems just wash up there good. I got it on my TL also I never have taken anything off.
Old Apr 24, 2001 | 08:00 PM
Wink
yeah i just took off the moon roof visor from my 91 accord and slapped it on my TL....looks JUST like the original!
anyway, when washing u don't need to remove it, but u might have to wipe duner it since at the car wash the "scrubbers" can't reach under there.
as for how it's held in place
it's 2 clips. once end is screwed with the visor, and the other end is attached to the moonroof...it's like a hook that hooks underneath the roof..bah hard to explain
anyway...I find that it makes the car more sporty and reduces wind noise like crazy ... I'd say it reduces sound by 70% ...very worth while if u find that the moonroof causes too much noise.
good luck on your moonroof!
le^2
Mar 17, 2026 05:06 AM
BoricuaTL
Apr 8, 2016 01:08 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
SUPRMN84
Oct 7, 2015 09:46 PM
jmaxima03
Sep 27, 2015 10:22 AM
