Misfires at highway speeds
Our 2001 3.2TL will misfire (characteristic bucking, and sometimes it's enough to flash the engine light) if it revs too high on the highway. Forcing an upshift will cause the misfiring to go away. It mainly happens on uphill grades. Our mechanic can't find a root cause. Any ideas? Ignition system? VTEC? Cylinder deactivation? Could it even be the fuel? (Disclaimer: We put regular in it because while, in typical luxury car fashion, premium is recommended, the manual says it is not required, and the worst regular should do is produce occasional knocking, and not heavy misfiring like is happening here).
"Your Acura is designed to operate on premium unleaded gasoline with a pump octane number of 91 or higher. Use of a lower octane gasoline can cause occasional, metallic knocking noises in the engine and will result in decreased engine performance."
Put some premium in it (yes I know it's expensive). and pull the codes to see if there are any pending.
TBH, that looks like the cheapest thing to try first. However, since it's heavy and feels like misfiring, I'm dubious. Very well could be a bad knock sensor, though, as far as I can tell.
whitetiger5 (02-16-2022)
whitetiger5 (02-19-2022)
