Strange issue with engine.
Old Jul 27, 2019 | 10:20 PM
Angrybear's Avatar
Hello,
7-10k miles I got a valve lash adjustment on my 2003 cl type s 6mt. Car is currently at 246k.
after the adjustment, I noticed the engine sounded dead quiet, had slight bit more power and I went from 20 mpg to 23-24mpg.
however, over a few thousand miles after the adjustment, I noticed that 5–7 mins after driving on a cold engine that’s warmed up, the car will buck at around 2k rpm. I just thought maybe my friend messed up on an intake valve...this sensation of bucking or Rpm suddenly dropping slightly and slight bucking is especially evident when the a/c compressor is on.
i had a small pull against a friend a few weeks back, 244k, and the next day my CEL was on. I got it checked and it was fuel related. Said something about running rich. However, the light turned off by itself in 30-40 miles of driving and turning the car off.
Considered my self lucky.
well, more recently, a day ago, I noticed my car running a bit odd during steady speed and rpm. So at 55 mph and 1850-1900 rpm, I’ll feel that the engine is losing power VERY SLIGHTLY, but it comes back. Some sort of hesitation...the loss of power results in just 50-80 rpm loss but returns
Today I got a CEL again, and I just kept driving around. I turned the car off, came back a few hours later and was going home and noticed the CEL light was off again. But on the way home it kept doing the hesitation thing once or twice until I turned the ac off.
not sure if I need new fuel injectors... we’ve replaced a coil pack that was bad 15-20k miles ago n the rest fired fine so I know it’s not a spark issue. Especially since we replaced the plugs during valve lash adjustment with ngk.
i admit sometimes I run really low on gas n not too long ago my car nearly died because I forgot my money at home. So not sure if I messed up an injector.
i use only 93 octane and run fuel injector cleaner,(lucas) and seafoam thru there very often.
Old Jul 28, 2019 | 01:52 PM
01acls's Avatar
Next time the cel comes on, get the code read instead of hope for the cel to go off. Best way to diagnose a car problem is to let the car tell you what's wrong or point you in the right direction.
Old Jul 28, 2019 | 01:55 PM
I agree, it's hard to diagnose the fuel injectors if it's not throwing a symptom...
it's hard to diagnose the fuel pump if it's not throwing a symptom....
if the car is running rich, perhaps it an 02 sensor
Old Jul 28, 2019 | 05:10 PM
Angrybear's Avatar
Sorry guys,
it was these codes from what I can recall:
P0170, p0172, p0175
acura1972
1G RDX Problems & Fixes
32
May 28, 2019 12:49 PM
getakey
Oct 26, 2005 12:58 PM
jmcrtp
Sep 4, 2003 08:00 AM
cusdaddy
Jun 18, 2002 09:20 PM
TxD90
Technology
Jul 31, 2001 01:57 PM
