Misfire 1-5 cylinders
Old May 11, 2017 | 05:10 PM
Luis Rivera787's Avatar
Alright guys please help me out anyone so I have an 03 tl type 's it's misfiring in 5 of the cylinders I changed the spark plugs iv checked the ignition coils I took apart the upper intake to clean out the egr ports iv done it all. So when Im at full throttle it down shifts just fine but work go no where it's not the transmission because when it's in park it does the same thing it stops at 4k rpm I can hear the motor misfiring like it has 2 step anti lag system but the car is stock I'm not sure if it's the fuEl injectors or it might be time to replace the timing belt does anyone know?? Please and thank you.
Old May 12, 2017 | 08:49 AM
teh CL's Avatar
Could be a clogged cat
Old May 12, 2017 | 09:02 AM
Nope
I deleted the cat I thought of that too.
Old May 12, 2017 | 09:04 AM
what plugs did you use?
Old May 12, 2017 | 09:11 AM
Spark plugs
Ngk laser iridium
Old May 12, 2017 | 09:17 AM
Are you getting a CEL for the random misfires? What kind of gas are you using?
Old May 12, 2017 | 09:20 AM
Gas
93 octane chevon gas is all I use
Old May 12, 2017 | 09:21 AM
Misfires
Cylinders 1-5 are misfiring number 6 is fine that's what's weird
Old May 12, 2017 | 09:23 AM
You've got a bad coil. Start removing them one by one and see if there's a change in idle. Because you've replaced all of the plugs, it's narrowed down to coil.
Remove one by one and report back removal of which bank does not change the idle.
If that doesn't work, go and clean your EGR valve and port.
Old May 12, 2017 | 09:28 AM
I did all of that I switch coil 6 to cylinder 1 still the same problem
Old May 12, 2017 | 09:31 AM
which coil didn't change idle?
Old May 12, 2017 | 09:33 AM
They all changed idle
Old May 12, 2017 | 09:34 AM
So all 6 coils changed idle? if so
Old May 12, 2017 | 09:37 AM
I cleaned the egr ports in the upper intake manifold and egr valve it's self
Old May 12, 2017 | 09:38 AM
well shit.. i don't know now. Throw in a bottle of Berryman's b12 in the gas tank and clean Throttle body..
If all else fails, junk the POS!
Old May 12, 2017 | 09:40 AM
I did a full induction and fuel cleaning
Old May 12, 2017 | 09:44 AM
it's dead jim. i got nothing.
Old May 12, 2017 | 09:48 AM
Well damn thanks tho lol
Old May 12, 2017 | 10:44 AM
Kris9884's Avatar
I had all the same symptoms and a combination of cleaning the EGR, new plugs and one new coil fixed mine. Make sure the EGR maze and ALLLLLLLL of the little holes that go into the lower manifold are cleaned and not clogged. I know you said you checked but check again, there's nothing left it could be. Maybe a bad harness or something. Try resetting the ECU again.
Old May 12, 2017 | 10:48 AM
I cleaned out every egr port and egr itself with a wire brush and blew it all out
Old May 12, 2017 | 11:02 AM
Kris9884's Avatar
So have you cleared the codes AND reset the ECU? If so, you're saying they still all come back? Time to push it off a cliff.
Old May 12, 2017 | 11:10 AM
Old May 12, 2017 | 11:12 AM
lol naw dude I love this car I haven't reset the ecu how u do that??
Old May 12, 2017 | 11:15 AM
Hazsun's Avatar
Do you get any other codes beside misfire 1-5? How many miles on the car? Could or maybe need valve adjustment?
Old May 12, 2017 | 11:18 AM
220xxx miles where can I got get that done
Old May 12, 2017 | 12:47 PM
Kris9884's Avatar
1. Insert and turn the key to the second position where all the dash lights and accessories turn on, turn off the AC and radio.
2. Remove the key.
3. Insert and turn the key to the second position again and immediately press the gas pedal to the floor and hold it for at least 30 seconds.
4. Remove the key and release gas pedal.
5. Insert key and start the car.
DONE!
If that doesn't work, disconnect the battery cables for like 30 minutes but you'll have to reset your radio settings..
Old May 12, 2017 | 01:03 PM
horseshoez's Avatar
Latent car nut
Just another datapoint...
My OBD-II reader reported misfires on four or five cylinders on my 2001 V6 Accord; one new coil fixed the issue.
Old May 12, 2017 | 01:15 PM
Wait a min are u telling that the coil system works like Christmas lights??
Old May 12, 2017 | 01:35 PM
horseshoez's Avatar
Latent car nut
No, not exactly. With some Christmas lights, when one bulb goes out, all of the rest of the bulbs downstream go out as well. On these V6 engines it seems one bad coil will only impact one cylinder, however, what comes out of the OBD reader is misfires all over the map. At least that's my experience.
Old May 12, 2017 | 01:47 PM
gnuts's Avatar
3.5 psi
disconnect the battery or remove the clock fuse which is in the little panel when you open the passenger door. (it's there on my CL, so I'm assuming it's the same on the TL).
I still think it's a bad coil. If you've never replaced any coils, just order a 6 new ones.
When the car is idling, if you hear loud ticking from the engine then your valves could need adjusting back into spec. Note that your purge solenoid might also be ticking which is near the drivers firewall (small black thing)...you can put your finger on it and feel the tick. That's not to be confused with valves out of spec.
Old May 17, 2017 | 09:03 PM
Tosh's Avatar
Eurotrash
If it hasn't had the valves adjusted since new, then this would cause those misfires. OM says check valve clearances at 105k. A handy person could check and adjust the clearances. That's how these motors often blow: by burning an exhaust valve that has receded into the head and gone tight (no ticking).
(Otherwise I would say replace all coils.)
Old May 17, 2017 | 09:51 PM
horseshoez's Avatar
Latent car nut
Whatever you do, do NOT replace all of the coils; change them as they fail, and right now, if coils is the OP's issue, there is only one bad coil.
Old May 17, 2017 | 11:43 PM
Tosh's Avatar
Eurotrash
I was traumatized by two coils suddenly going out at only 111k, so I say get them out. Move on to the next step in the diagnosis: valve adjustment.
Old May 19, 2017 | 01:10 PM
Kris9884's Avatar
Yeah, I still say its either a coil, plug or EGR. good luck lol
