maybe a fuse?
Old Feb 28, 2010 | 10:13 PM
taintedplay's Avatar
maybe a fuse?
so i was working on my ac controls, and finished and went inside.
came back out, and now my locks dont work. Well, when the engine is on, my door lock buttons work. when the engine is off, neither the keyfob, or the actual buttons on the doors lock or unlock the doors. did i maybe blow a fuse?
Old Feb 28, 2010 | 10:18 PM
It's Clutch's Avatar
Hello Officer
Maybe you have the hood/trunk/door that you forgot to close.
Old Feb 28, 2010 | 10:26 PM
just checked, all are closed
Old Feb 28, 2010 | 11:05 PM
03tLsNBP's Avatar
MechEng
sounds like you did blow a fuse. use the schematic in the owners manual and check the appropriate fuses.
Old Mar 1, 2010 | 08:46 AM
laziebun's Avatar
if it were the fuse it shouldnt work at all. What were you doing to the AC controls?
Old Mar 1, 2010 | 07:47 PM
well in the past i had installed a monitor where the ac controls were and moved those to the glovebox. i was moving them back to stock placement
Old Mar 2, 2010 | 10:58 AM
totaledTL's Avatar
You had the air cond. & heater controls in the glovebox?
Old Mar 3, 2010 | 11:56 AM
yup. all it was was extending wires to get it there, real easy. i think i popped a fuse tho as when the cars not on, the electric locks dont work :/
Old Apr 27, 2010 | 01:04 PM
alright i finally got around to testing it. the fuse labels door locks is NOT blown, so now i am clueless. key fob does nothing, and when im inside the car, the switches wont work when the cars off. When the cars on, i can unlock the doors but cant lock them. it pretty much feels like when the car is off, all power to inside stuff is off. so maybe something to do with a fuse related to ignition vs power?
Old Apr 28, 2010 | 05:39 PM
anyone?
Old Apr 28, 2010 | 11:21 PM
jdjohn84's Avatar
2003 TL-S w/Navi NBP
Maybe pull the main clock fuse or the negative battery cable off for awhile. Let the ECU reset, reconnect the juice, then try everything again.
I recently had my alternator off, and both battery posts undone. When I reconnected everything, the second push on the keyfob lock button didn't beep like it usually does. When I checked it later (maybe after driving it) it started beeping again on the second push. Go figure.
Old May 1, 2010 | 04:45 PM
il try that^
so my thoughts were, that since basically everything doesent get power when the cars off, maybe a fuse blew on the power. Once the car is on though, power flows through the ignition cable giving everyhitng power. In the underhood fuse box i didnt find anything like main power or ignition, the closest being accessories something. It wasent blown
Old May 2, 2010 | 12:39 AM
also, i got a remote start, it would prob be a good idea to wait till this clears up to install it wouldent it?
Old May 2, 2010 | 07:54 AM
fsttyms1's Avatar
Start checking ALL the fuses (from all 3 fuse panels)
Old May 2, 2010 | 01:30 PM
fixed it! it was the clock backup light in the passenger panel. whats wierd though, is there were no fuse for day lights. so i put one in from the spare ones(later had to take out and put in the clock backup) but it wuold just fall out, like the internal crimps were loose
Acura604
20
Aug 5, 2017 12:55 AM
Skirmich
Oct 1, 2015 12:59 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
ripit
Sep 26, 2015 06:19 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
