Maintenance Required Light keeps blinking!
Old Jun 21, 2004 | 08:09 AM
tgoines's Avatar
4th Gear
I don't know if I'm crazy, but on Friday night I noticed that the maint. req'd light blinks when I start up my car. The car has been feeling a little off last week. It seems like I lost some power. I bought the car in February and I had to get 2 coil replaced connecting the 4th and 6th cylinders. The car is becoming a headache. If you have any advice or info, please reply.
Old Jun 21, 2004 | 08:22 AM
Bxscig's Avatar
Last time that happened to be was because of the oil change. They never reset my computer when they did the oil change so the car thought it'll let me know.
Old Jun 21, 2004 | 08:39 AM
ItalnMuslNYC's Avatar
Did you reset the maint. req'd light so it stops blinking?? It's easy to do.. I believe you have to hold down the "select" and "reset" button next to your odometer together as you start up the car. It's in the manual how to reset it. But just bring it to the dealership to find out what's wrong with it!
Old Jun 21, 2004 | 08:41 AM
Brian_C6's Avatar
Shut car off. Hold select and reset buttons on dash. Start the car and continue holding for 10 seconds.. the light should shut off. The light will shut off when it's been reset.
Brian
Old Jun 21, 2004 | 08:42 AM
joecooool's Avatar
It comes on automatically at certain miles. Its an idiot light designed to make you go to the dealership and spend money. Just turn it off using the process above.
Old Jun 21, 2004 | 08:44 AM
fsttyms1's Avatar
Brian
the light is a reminder for oil changes. its supposed to be reset every oil change.
you can follow the steps above but you dont need to start the car to do it. just turn the key to the run position. also dont turn the key first then push the buttons, you will change your temp gauge
Old Jun 21, 2004 | 09:22 PM
GaddAMIT's Avatar
yea I have changed the temp gauge before, and Im not exactly sure how to get it back accurate, how do I change it again? thanks
Old Jun 22, 2004 | 12:32 AM
seattle dale's Avatar
wow i didn't know that about the tempreture gauge, it seems like my outside temp runs 3 to 4 degrees warm. Is this how you can syncrinize your outside temp.?
Yikes
May 3, 2021 04:29 PM
BigJilm
Sep 21, 2015 08:32 PM
PortlandRL
Sep 14, 2015 12:01 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
datadr
Sep 12, 2015 09:12 PM
