Maintenance Required Light keeps blinking!
4th Gear
I don't know if I'm crazy, but on Friday night I noticed that the maint. req'd light blinks when I start up my car. The car has been feeling a little off last week. It seems like I lost some power. I bought the car in February and I had to get 2 coil replaced connecting the 4th and 6th cylinders. The car is becoming a headache. If you have any advice or info, please reply.
Did you reset the maint. req'd light so it stops blinking?? It's easy to do.. I believe you have to hold down the "select" and "reset" button next to your odometer together as you start up the car. It's in the manual how to reset it. But just bring it to the dealership to find out what's wrong with it!
Shut car off. Hold select and reset buttons on dash. Start the car and continue holding for 10 seconds.. the light should shut off. The light will shut off when it's been reset.
Brian
Brian
Brian
Brian
you can follow the steps above but you dont need to start the car to do it. just turn the key to the run position. also dont turn the key first then push the buttons, you will change your temp gauge
