Maint. Req'd light??
Old Oct 10, 2005 | 03:05 PM
MY2002TLS's Avatar
Exclamation Maint. Req'd light??
My 2002 TL-s has just under 65,000 miles on it. Last week my Maint Req'D ligfht came on.
Anyone have any suggestions on what to do?
No budget for taking it into a shop, what can I do myself?
Thanks in Advance...
Old Oct 10, 2005 | 03:15 PM
snowman81's Avatar
Sippy Cup (x2)
check out these threads...you can reset it yourself. the first one explains it.
https://acurazine.com/forums/search.php?searchid=162693
Old Oct 10, 2005 | 03:23 PM
LiquidThinker's Avatar
Playing Naked!
Have you done the maintenance required?
Old Oct 10, 2005 | 03:32 PM
FuzzyNutz's Avatar
Easy fix,.. just turn off the car, hold down the tachometer reset button while turning the ignition to the II position and hold until the light goes off. (about 10 seconds). It's just an automated warning light that comes on every so many miles. It will never indicate any actual problems. That's what the check engine light is for. You can read more about it in your manual if you have one.
Old Oct 10, 2005 | 03:33 PM
FuzzyNutz's Avatar
sorry,.. not the tachometer,.. but the other display with the mileage. duh.
Old Oct 10, 2005 | 03:45 PM
fsttyms1's Avatar
The Trip and Reset
Old Oct 10, 2005 | 03:57 PM
MY2002TLS's Avatar
Originally Posted by fsttyms1
The Trip and Reset
I tried the select and erset button and held it for like 30 second with the key on the run position, the light did not go out!!
Old Oct 10, 2005 | 03:58 PM
MY2002TLS's Avatar
I dont have a manual for my car unfortunetly can you enlighten me?
Old Oct 10, 2005 | 04:00 PM
fsttyms1's Avatar
Push the Buttons in THEN turn the key to the run position. Hold them for around ten seconds (or until the light goes off) If you Do it wrong (turn the key then push the buttons) you will be adjusting the temp reading a few deg.
Go try it again
Old Oct 10, 2005 | 04:08 PM
MY2002TLS's Avatar
That link was perfect thanks!!!!!!!!!!!!!!!!!!!
Old Oct 10, 2005 | 04:14 PM
MY2002TLS's Avatar
Go try it again
Got it!!!!!!!!!!
CCCCCCCOOOOOOOOOOOOLLLLLLLLLLLLLLL
Old Oct 10, 2005 | 05:13 PM
FuzzyNutz's Avatar
yeah,.. what he (fsttyms1) said.....
Old Oct 10, 2005 | 06:35 PM
snowman81's Avatar
Sippy Cup (x2)
Glad I could be of some help
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
heykosal
1G RDX Problems & Fixes
Feb 27, 2016 06:43 PM
Greengecko
Sep 16, 2015 08:19 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
