Maint. Req'd light??
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
My 2002 TL-s has just under 65,000 miles on it. Last week my Maint Req'D ligfht came on.
Anyone have any suggestions on what to do?
No budget for taking it into a shop, what can I do myself?
Thanks in Advance...
Sippy Cup (x2)
check out these threads...you can reset it yourself. the first one explains it.
https://acurazine.com/forums/search.php?searchid=162693
Easy fix,.. just turn off the car, hold down the tachometer reset button while turning the ignition to the II position and hold until the light goes off. (about 10 seconds). It's just an automated warning light that comes on every so many miles. It will never indicate any actual problems. That's what the check engine light is for. You can read more about it in your manual if you have one.
Originally Posted by FuzzyNutz
sorry,.. not the tachometer,.. but the other display with the mileage. duh.
Originally Posted by fsttyms1
The Trip and Reset ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
I tried the select and erset button and held it for like 30 second with the key on the run position, the light did not go out!!
Go try it again
Push the Buttons in THEN turn the key to the run position. Hold them for around ten seconds (or until the light goes off) If you Do it wrong (turn the key then push the buttons) you will be adjusting the temp reading a few deg.
Go try it again![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Go try it again
CCCCCCCOOOOOOOOOOOOLLLLLLLLLLLLLLL
mada51589
05-03-2022 08:54 PM
Greengecko
09-16-2015 08:19 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
