Lug Nut Lock
Old Aug 18, 2009 | 01:37 PM
jrb9790's Avatar
Lug Nut Lock
Well I had uh boo boo and broke of the key inside a lug nut and now don't have a way to get my other lock keys of the wheel if I get a flat tire..
Is there anyway I can just get they key instead of a whole new kit?
Old Aug 18, 2009 | 01:40 PM
hANDYcaptd's Avatar
It's the Halladay season!
Yup, they sell the key by itself. I had to get one when I bought my car.
I'll try to find the site...
Old Aug 18, 2009 | 01:49 PM
hANDYcaptd's Avatar
http://www.mcgard.com/Home/About/Cus...placementParts
I ordered it from Mcgard. But it's been 2 years. I THINK I called them up to order.
But it seems like with their ordering process, you need the original kit's registration card and all that.
Old Aug 18, 2009 | 02:15 PM
jrb9790's Avatar
cool! Thanks ill check it out
Old Aug 18, 2009 | 02:54 PM
SLushhYYY's Avatar
Keep It Simple in
or you can go to the dealer and buy it for 30$
Old Aug 19, 2009 | 06:20 PM
themiccivic's Avatar
What to put
In my experience dealer took old ones off but they didn't sell just the key I would have had to buy another whole set and they told me the keys are random they don't know what one comes In the package. when they took mine off when my key broke (same situation) they had a master like key set they had to try them Individually till they found the one that fit my lock to take them off so I don't think there are any numbers to go off of I may be wrong but my dealer didn't know either.
Old Aug 19, 2009 | 07:04 PM
hANDYcaptd's Avatar
Your dealer is stupid. It's not random. They can definitely match keys to cars.
They're trying to make you buy the whole set and take your money...but what else is new?...
Old Aug 21, 2009 | 09:41 PM
What to put
How is that when the lugs don't have a single number on them and the keys only have the same pat. number. They all have the same thing written on all of them I checked as I tried to use friends that had factory locks but none of them worked so I went to the dealer. All of there keys had the same numbers I tried like 4 or five others. So how to tell with out test fitting maybe your dealer has a bunch of open pairs they will let you try before you buy them but the dealers by me don't open them before you buy them. Someone posted that they come with a card I don't know I didn't buy my car new and I didn't buy new OEM locks for the price they wanted either so I don't know about a card. You also have to make sure you have Acura locks the Honda ones are different Acura are like 5 point the Honda ones are like 6 points and dealers by me they don't carry the opposite master key sets so if you find someone put ones from a Honda you would have to go to Honda to get them taken off. Also when the dealer took mine off they had a small I think it was red case with about 8-10 keys in it they were in no special order he tried them one at a time till he found the one for my car and at the time I had a Honda went to Honda to get it removed as I thought it was a Honda lug and found out after Honda tried all the ones they had it wasn't a Honda lug so they sent me down the road to the Acura dealer luckily it was an Acura factory lug as the company that makes them for Honda and Acura also makes them for other people.
Old Aug 21, 2009 | 10:57 PM
TLin401's Avatar
'13 Hyundai Sonata
You could do this:
Originally Posted by bigwerm187
you get a soket that will fit in there tite and u hammer it in till it gets stuck. then you can put ur rachet or a braker bar on it and there you go it comes off. lololol.....
Originally Posted by KrayzieDxC
werd just do what big werm said i think it was 3/8 in standard tap in it with a hammer and use a breaker bar i use this on my sis lexus rx300 when i lost her key nut
Originally Posted by DarkNinja75
Got them off. Tried going to some local tire shops but they wanted $20 per tire. I tried it with a breaker bar but didn't have any luck. Luckily my friend has an impact wrench. Hammered on a 19mm socket, spun the wrench, and off they came.
Someone on the 1G side had bought the car and they were not given the wheel lock so they had to get it off.
Old Aug 21, 2009 | 10:59 PM
hANDYcaptd's Avatar
^^ Wow, space that out my man. Gather your thoughts, and use periods...lol
I can barely understand what you wrote. I'll try to find the card I used and take a pic.
Do you have the original packaging of the locks and key?
Old Aug 22, 2009 | 01:33 AM
01tl4tl's Avatar
iirc- there were 5 lock keys- most dealers had a set in case owner didnt bring it with the car--big problem when that happens..hard to do a brake job with no lug lock!
You could a few years ago- buy 1 replacement from parts dept
There are not markings/codes visable so its harder for thieves to get wheel locks.
Kind of like the torx #20 security screws on the headlight back opening to the bulb are supposed to be an anti theft device...
forcing crooks use a prybar against the hood instead and taking the entire housing!,,,leaving behind only the mounting tabs
Now if they want your wheels the whole car is gone in 15 seconds
Old Aug 23, 2009 | 12:11 PM
jrb9790's Avatar
yeah, well idk about your dealership but I just rolled in and told them the problem I was having, they brought out a tech and like 3 minutes later all of the locks were off my car
buttttt now I am driving with 4 lug nuts... :/
MrHeeltoe
20
Feb 23, 2023 01:54 PM
neuronbob
23
Jul 16, 2019 10:48 AM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
