Lower Questions
Lower Questions
I've decide to go with Comptech springs for lowering. Do I also need to get the camber adjustment kit with this??? Any body know the clearence with a OEM body kit?? Where would you take your car to get them installed?? the only place i could think of is places like Firestone, but i dont think i would want that. Do I need anything along with spring?? Sorry I know its been beaten to death, but I read and its still confusing.
A few answers:
1. You don't need a camber kit with Comptech springs.
2. Most people take their cars to a performance or suspension shop, my experience was that places like Firestone/Goodyear/etc. won't want to touch your springs. Your dealer will charge way too much. There must be a perf shop in your area.
3. You will probably read about people adding other suspension modifications like thicker front/rear sway bars and strut bars if you do a search. I haven't found them necessary yet, but they do reduce body roll in the turns and I am considering adding them in the future. Simply adding the springs reduced the body roll on my car.
I don't have a body kit, so I can't answer that question.
http://acura-tl.com/faq.htm#18 should help with the clearance Q'S
Re: Lower Questions
Beason - not sure what yr your TL is.
I had Comptech springs added to my 2000 at a local Honda dealer for $90 about 3 yrs ago.
I got almost 2" drop in front and about 1" in rear. No camber kit, stock shocks and no problems after 3 yrs (45K miles).
I have the OEM body kit except for the front spoiler (too low of clearance and the bra doesn't fit with the spoiler).
I'm currently running 215/60 Pilots on stock rims. Wheel well clearance is 2 fingers in front and 3 in rear (with nobody in the car). Next set of tires will probably be 215/55 or maybe 17" type S rims if I can find some cheap.
You'll be happy with the ride of Comptech springs (not really stiff at all) and the look (w/OEM body kit) and handling will be impressive.
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
