Loud Humming Sound
Old Mar 17, 2006 | 08:47 AM
cejody's Avatar
Loud Humming Sound
My car is making a loud humming sound and it usually gets louder when I turn the steering wheel. any diagnosis?
Old Mar 17, 2006 | 08:54 AM
acutee's Avatar
check you power steering reservoir level. If it is dark, try to suck the fluid from reservoir out and refill with the new fluid, and see if that help. with the car in parking, does it make noise when you try to turn the wheel left and right or revving it ?
Old Mar 17, 2006 | 08:56 AM
optomos's Avatar
I=X - optomos
I would first check to see if power steering pump is low on fluid.
Old Mar 17, 2006 | 09:00 AM
cejody's Avatar
yes when the car is in park and i turn the steering wheel left or right it the sounds gets louder
Old Mar 17, 2006 | 09:01 AM
cejody's Avatar
i checked the fluid and its not low
Old Mar 17, 2006 | 09:19 AM
RickRoush03's Avatar
RickRoush03
probably a wheel bearing, i had my right rear replaced, it started as a low hum at slow speeds and got louder the faster i went. cost me $185 to get fixed at acura.
Old Mar 17, 2006 | 11:20 AM
PenancE's Avatar
^^^ its not his bearing if he hears it when the car is not in motion.
something with ur power steering tho....im sure of it.
Old Mar 17, 2006 | 03:06 PM
RickRoush03
ah, sorry, didn't see that car in P on his following post. i can say that the power steering unit was replaced on my car by the previous owner under warranty.
Old Mar 17, 2006 | 03:32 PM
fsttyms1's Avatar
Do you have a intake?
Old Mar 18, 2006 | 07:25 AM
snowman81's Avatar
Sippy Cup (x2)
I would think that it would be the power steering pump going, but I'm not sure. I've never had it happen to me.
Old Mar 18, 2006 | 11:01 AM
dvsxlt247's Avatar
99TL-p 114K
Check to see if your power steering fluid is low. When its low and you turn the wheel, it makes that nasty humming sound. Just get some powering steering fluid for your car and fill it back up. That should eliminate the nasty sound. I did the same and have no problems now.
Old Mar 20, 2006 | 08:25 AM
cejody's Avatar
over the weekend i put some power steering fluid because I saw that it was definitely low, but the noise didn't stop immediately, so i figured it needed some time, but maybe about an hour later the noise still remained and the power steering fluid had leaked out onto the ground....so at this point it could be what?? the power steering pump maybe???
Old Mar 20, 2006 | 09:09 AM
fsttyms1's Avatar
If what you poured in leaked out, you need to find where its leaking from. Fill it back up, start the car and have someone turn the wheel to the right and left (a bunch of times) while you look for leaking. You need to find out where its leaking from we dont know. It could be many things from a rubber hose to the pump to the PS rack.
Old May 10, 2006 | 07:06 PM
Jamesmoore's Avatar
Is there a DIY to replace a front wheel bearing? I cannot seem to find one.
Thanks,
James
Old May 10, 2006 | 07:10 PM
PenancE's Avatar
^^ wtf? rofl..
Old May 10, 2006 | 07:26 PM
Jamesmoore's Avatar
well i guess from that answer it must be too easy to have one. I just want to make sure I dont f something up.
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
merc009
Sep 29, 2015 03:06 PM
hashbrown
Sep 29, 2015 12:13 PM
