leaking REPLACED tranny
I have a 99TL. my tranny died about a month ago. just a few days ago i found out my tranny is leaking.. (red fluid allover the place). my tranny fluid tank empties out in like 2 days and i end up refilling it everytime. im just driving on it for now, but how soon do you think my tranny will go before i can get another one???
ive only driven about 500 miles on this one so far.. but i just cant stand at the fact that i have to lose my car for another week and get an old 4-door integra as a rental again.
Originally Posted by MikePA
What 'tranny fluid tank' are you referring to?
id bring it back right away and have them find out where its leaking. a low on fluid tranny is bad news
Are the replaced trannies supposed to have the jet kit on them as well? I have seen the pics on here showing where the jetkit is installed, and while doing the intake on Sat I looked for the kit and didn't see it....
Originally Posted by AcuraTl203
the replacement trannies have the jet kit installed internally , u can only see the jet kit on the original trannies that had the recall done
OK cool - Thanks! - I am noticing some 'irregularities' in the shifting of my replacement already - it's only been a few weeks, and I'm getting some hunting for gears, etc that was the beginning of the end for the last one.....
gah this is so annoying. when i spray water underneath the car to wash the drips out, i see red spilling down my driveway mixed with the water!! MY CAR'S BLEEDINGGGGG
damn acura ramsey. im gonna kill those guys. this is the third time in a row they mesed up my car
Originally Posted by aaronnn
there's a little dipstick by the battery that reads your tranny fluid level.. im referring to that, because everytime i check, only the way bottom tip has red fluid on it. after i drive some more, i check it again and there is no wet marks on the dipstick at all.
Originally Posted by progz
My mechanic told me to start the engine before checking the tranny fluid. Any truth to this???
Engine at normal operating temperature, on level surface and NOT running.
It's truly amazing what information lurks in the Owner's Manual.
My mechanic is right though on most of the cars:
http://www.samarins.com/maintenance/...html#automatic
Question, how can you set the engine at normal operating temperature? Should you start the engine first until the temp moved up and turn it off and then look at the tranny dip stick? When you say NOT running do you mean the engine is off or the car is not moving???
start teh car (drive it around if you feel like it) then park on a level surface shut the car off and test it. most cars require you to have the car running when testing it and some want the car running and in gear while testing it (having 2 people here helps) but honda wants teh fluid warm and the car off
when i tested it, myself and mechanics at the dealership, we had the car running. i let the car warm up first, just let it sit idle for a good 2 minutes, and then checked the dipstcik while the car was still on. and yes, even with the car running, my tranny level was unusally low. my transmission is leaking and i only drove 14 days on it. what's acura trying to do to meeee?!?!?!? i freakin love my car too
cycdaniel
12-17-2019 10:58 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
